Problems with 5 speed Split shift
Discussion in 'Experienced Truckers' Advice' started by SirTJ79, Oct 23, 2011.
  1. SirTJ79
    SirTJ79 Bobtail Member
    19
    Oct 23, 2011
    Yes thanks, I am getting the hang of it..I understand the process, but it just seems like over kill splitting the gears so often....,
  3. Hammer166
    7,606
    27,796
    Aug 18, 2007
    ~8600+' and loving it!
    You don't have to split all the time, only when you need the half step.
  4. SirTJ79
    19
    Oct 23, 2011
    gotcha, So im taking there is more then one way to shift...Seems splitting with a heavy load would be unnecessary?? I was just making sure im not hurting the truck..?
    like with my twin stick mack,,,,everyone tells me i need to use to hands, use both sticks at once, put your hand through the steering wheel....I pull very easy just running 1-5 on 1 stick and in 4 on the other, then bump it up to 5 high.....??
  5. Hammer166
    7,606
    27,796
    Aug 18, 2007
    You got it! You only split if a full shift is more than it'll pull.
  6. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    light loads you wont need the half shift and so forth. You got it !
  7. Mr Ed
    Mr Ed Road Train Member
    1,380
    1,630
    Apr 6, 2009
    Retired in Taunton Ma
    Drove a bunch them with underpowered motors,....ah, the good ole days!
  8. SirTJ79
    19
    Oct 23, 2011
    So today I was able to test it out...I feel very dumb never spitting in any other gear then 5 high.....everything was great pulling up the switch, but when I pushed it back in that bad boy did not want to engage...A little rumbling and no power for a few seconds,,,,,,And the trick with my truck is that she only like to split at low rpms,
  9. Hammer166
    7,606
    27,796
    Aug 18, 2007
    When you split down, you have to make sure you're bringing the rpm up, with the transmission in gear and the clutch engaged. Think of how you would have to do it if it was a lever, and not just a button.
  10. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    I have had a 16 Spicer, 32 Brownlite, I fell to my knees when the 13 over came out and said thanks! Drive it son, the only way to learn. :)
  11. SirTJ79
    19
    Oct 23, 2011
    I think I skipped the clutch part...So no clutch when pulling up, clutch when pushing back down... I think that settles it
