Problems with a few gauges sticking?
Discussion in 'Peterbilt Forum' started by Loaderlou, Aug 15, 2017.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    Hi everyone. I have a 2003 Pete 379 and recently my water temp and oil temp seem to be stuck. They start the day at about 180 degrees then climb to over 200 and stay there. My trans temp gets to about 195 when shifting a lot. Any help would be appreciated.
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    simple things first, check all dash/body grounds. something could be broken, or loose.
  4. Loaderlou
    342
    131
    Feb 24, 2014
    Thanks buddy. So much spaghetti back there with 18 gauges. I need a day to go through it. Better than burning the truck down.
  5. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    I would start by checking the ground leads to the faulty gauges.
  6. Loaderlou
    342
    131
    Feb 24, 2014
    I found it. Bad ignition to the gauges. Couldn't actually find the break so I ran new wires. Everything works fine. Thank you for the come backs fellas
