Progressive shift and load or weight management. Heavy D?
Discussion in 'International Forum' started by EZ Money, Jan 24, 2015.
Page 2 of 2
Sorry, I was out of the shop today. I am back in tomorrow though. Before we go any further, is this a 10 speed auto or manual trans? If it is an auto, the trans commands the engine and the shift points, not really the engine. The RPMs at which the shifts occur are based on engine load, rpm and road speed. This is further determined by what kind of application or shifting parameters the transmission is programmed for to optimize. Some trannys are programmed for heavy haul, others for fuel economy and so on. The shift points can really be tinkered with to get you what you want. If you have an Eaton you need Service Ranger software and probably a pro version in order to change those parameters.
EZ Money Thanks this. -
Thanks Heavyd,
Manual 10
The shop gave up on it today so i'm not getting anywhere else with them.
I have the password to the ECM so time to get a Diesel Doc tune thrown on it.
Talked to some of the other drivers and that is what they are running.
The truck pulls pretty decent if you can keep the rpm up.
Just that drop from 10th to ninth you have to lug it way down......kills me on a steep hill with 45k on.
For some reason 6th and 7th also are messed up to,got to shift at 1100....drives me nuts.
Get a good tune for about 200 bucks so see how that goes... -
I plugged into a 871 today. Yep, load based speed control. The other parameter I see here is "Powertrain Protection". It is disabled on this truck. Another to check is, "Switched maximum engine operating speed". I don't know what it does, but it is also disabled on this truck. Other than gear down protection I don't see anything else that could regulate engine speed like that. One thing I have seen on Prostars is the that how the engine is programmed to electronically communicate with the cab does get scrambled sometimes during reprogramming, low battery cranking events, or boosting. This can cause weird issues like this.
Good info! Thanks......The boss is no longer going to let the shop mess with it.
I noticed Powertrain protection and max engine speed but the guy would not touch that.....And they hide the laptop...lol!
Wish I knew of a shop that would get it right for cheap....
Thanks for the help though Heavyd!Heavyd Thanks this.
Page 2 of 2
