proheat gen 4
Discussion in 'Canadian Truckers Forum' started by WHITEINDIAN, Dec 28, 2010.
  1. WHITEINDIAN
    WHITEINDIAN Bobtail Member
    11
    winnipeg manitoba
    hey y'all i'm looking for a manual for an older gen 4 proheat apu. there website doesn't even acknowledge them anymore. got some bad fuel in illinois changed the fuel filter back here in winnipeg now it'll run forever but i have no heater, a/c or fan nor does the generator work. i can live without the fan and heat/ a/c for now but would really like the electricity. any ideas? either on where to get a manual or whats wrong?
  3. rambler
    rambler Road Train Member
    1,358
    582
    Nov 5, 2007
    I have a pro heat (newer model '07) on my tractor but havent had any issues at this point. There may be fuses in the unit like the newer models have? Is there any breakers/fuses inside that you have noticed? Come to think of it I had a breaker on the generator to trip one time and the reset was almost hidden kinda on the bottom side of the generator. Once I reset it I got power back to the 110v plug in inside the cab. Your belt could/may be worn or stretched causing improper operation also. I would start with a call to proheat and talk with a tech on troubleshooting it or find an authorized repair facility if possible.
    WHITEINDIAN Thanks this.
  4. rambler
    1,358
    582
    Nov 5, 2007
    I went out to the tractor and got the owners manual for my Gen4 which is actually an 06 model. If you don't already have the info here it is:
    Teleflex Energy Power Systems
    3831 No6 Road
    Richmond, BC, Canada V6V 1P6
    (604) 270-6899 Telephone
    (604) 270-0137 Fax
    Hope this helps you.
  5. Trouble65
    Trouble65 Medium Load Member
    621
    147
    Jan 11, 2009
    Ontario Canada
    Please pm me your email and I will send you what you need in PDF format.
