Propane haulers
Discussion in 'Hazmat Trucking Forum' started by Badmon, Dec 25, 2020.
  1. Badmon
    Badmon Heavy Load Member
    806
    1,503
    Oct 6, 2014
    Deep south
    Anyone? I recently started and have questions
  3. 91B20H8
    91B20H8 Road Train Member
    2,946
    3,315
    Oct 17, 2012
    The Heart of the North, Mi
  4. Badmon
    806
    1,503
    Oct 6, 2014
    Deep south
    Okay if i have an emergency and #### is leaking like mad and i need to shut down my valves on either end, trailer or storage tank end, walk me through what you would do. Im curious how long youve been doing it and how many times youve been burned
  5. 201
    201 Road Train Member
    12,790
    26,318
    Apr 16, 2014
    high plains colorado
    Shut it off at the source, the trailer( or truck) A leak of any kind is usually pretty serious stuff.
    McUzi and Badmon Thank this.
  6. Badmon
    806
    1,503
    Oct 6, 2014
    Deep south
    Ive just started doing transport in a 18 wheeler. The other day it was rainy and cold and after unloading and while bleeding off the tank, for the first time i noticed the cloud shoot up out of the little bleeder tube and come tf back down and surround the back end of my trailer. Scared my drawers brown just to find out that it does that every time, you just cant see it every time. Not to mention by the time i was done the entire pipe on the storage side right up underneath the wheel valve was frosted over. Of course all of my connections were tight, it was the plant's end of things that had the slight leak. Yikes
    RockinChair Thanks this.
  7. Texas_hwy_287
    Texas_hwy_287 Road Train Member
    2,097
    2,407
    Sep 25, 2016
    Texas
  8. RockinChair
    RockinChair Road Train Member
    5,385
    14,437
    Feb 19, 2012
    Lubbock, TX & thereabouts
    1. Stop the pump.
    2. Stop the leak as far as possible upstream at the source.
    If the leak is on your trailer, activate the emergency shutoff on the trailer, there's one on the back right and one at the front left. If your internals are air-operated you will either flip a switch or turn a valve handle. If your internals are cable-operated there will be a handle for you to pull.
    If the leak is on the customer's side then go throw the little switch (or plunger) that opens and closes all the vapor-actuated valves in the customer's piping.
    3. Block-in all of the other valves that you opened in order to unload.
    The colder it is outside, the more condensation you will see coming out the back when you open the bleeder. If your customer is fussy about it then just open the bleeder a little bit so that the cloud won't be quite so big.
  9. Badmon
    806
    1,503
    Oct 6, 2014
    Deep south
    Dude thank you. Wish i could double thank this
    MrJoop and RockinChair Thank this.
  10. Dale thompson
    5,454
    47,215
    Nov 20, 2013
    commerce twp,mi
    Every time you finish loading or unloading there’s pressure in the hose between the valves that must be released before disconnecting. Frosted lines are normal pay attention to the tank temperature and outside ambient temperature and always pay attention to wind direction when unloading ( this is really important when hauling NH3 ) sometimes there is some liquid in your hose which makes a bigger vapor cloud when blowing off.
    RockinChair, Badmon and wis bang Thank this.
  11. Bumblebee101
    Bumblebee101 Light Load Member
    91
    107
    May 17, 2018
    Massachusetts
    Propane is lighter then air. It will raise pretty quick. When it rains it slows it down some. I work with blowing gas all the time. Specially natural gas. If it’s blowing like crazy you are good. It won’t ignite. Well until after you stop it from blowing and the air mixture changed then something may happen if there is an ignition source.
