Proper or improper securement of this pickup on step deck?
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by striker, Sep 27, 2021.
  1. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    Watched this pickup being loaded on a step deck today, this is how the driver was securing it at all 4 corners
  3. Arctic_fox
    4,605
    26,372
    Sep 16, 2016
    Lolno....not only no but HELL no. The brakes on that truck fail and its going to roll all over the place and torque the hell out of the straps and likely break them, or cause damage to the rims at a minimum. Vehicles have tie down points for a reason. Using a basket (over wheel net designed to hold the entire wheel) would likely be ok as well though on a pickup unless its a half ton id be iffy at best for that in most cases.
    If you wanted to do what this guy is doing as ADDITIONAL securement incase something fails or to avoid excessive movment if the brakes ARE bad then sure maybe especially if you had something to protect the rim. This is just asking for problems and i have seen a few vehicles fall off trailers with this kind of securement.
  4. Hammer166
    7,620
    27,893
    Aug 18, 2007
    ~8600+' and loving it!
    The regs are really specific on vehicles. You have to use the slots in the frame designed for tiedown, or Straps over or around the TIRE.
    My guess is he only has flat hooks on his straps, so he can't even do the trick of running chains on either side of the tire for strap anchor points in line with tires
    BigBob410 and striker Thank this.
  5. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    I still see various car haulers strapping through the wheels. It is beyond irritating as car dealers began checking wheels for EVERY car hauler because a few are hard headed. A local BMW/Mercedes dealer where I used to live insisted on coming out to the trailer when their used cars arrived because wheels were coming in scratched.
    BigBob410 and Hammer166 Thank this.
  6. Hammer166
    7,620
    27,893
    Aug 18, 2007
    But we're the ######## for calling them out for doing it.
    feldsforever, BigBob410 and LBZ Thank this.
  7. BigBob410
    BigBob410 Road Train Member
    5,665
    74,101
    Feb 2, 2016
    Beirut on the Bay, MD.
    I know most of the new car manufacturers won’t even let you use the lasso type straps. And yeah thru the rim is a definite no. He could have gone around the tire or hooked into the frame.
  8. Bill O’lading
    Bill O’lading Light Load Member
    106
    107
    Aug 11, 2019
    I have seen worse with new fords on little trucks.
    Hammer166 Thanks this.
