Prostar with Bendix radar
Discussion in 'International Forum' started by Packer1077, Nov 5, 2020.
  1. Packer1077
    Packer1077 Bobtail Member
    27
    15
    May 12, 2020
    Arizona
    Receiving “abs module “ code in mileage box area. After reading HeavyD’s previous posts, I pulled harness from radar and DIU to test. DIU had 0 voltage on J1939 to ground. Radar side of harness voltage was 0.3 for power supply and no voltage reading j1939 high side. Did some research and it’s recommended to replace entire harness. HeavyD, can old harness stay on truck (disconnected) and run the new harness along side of it? Also is there a wiring diagram for this harness available?
  3. Heavyd
    Heavyd Road Train Member
    7,828
    6,277
    Feb 4, 2009
    Yes, just run new wires. Complete replacement harnesses are not easy to get and not easy to get the right ones either. Most radars only have 4 wires. Pink is 12 volts, white is ground, and yellow and green are your datalinks.
  4. terminater76
    terminater76 Bobtail Member
    May 1, 2022
    Can you please let me know if the new harness comes with only two wires mine did. Do I just transfer the other two wires?
  5. Heavyd
    7,828
    6,277
    Feb 4, 2009
    If the new harness is missing the wires I would first see if they got you the right one. If so, then you will have to run new wires.
