Pulling 20ft doubles
Discussion in 'Intermodal Trucking Forum' started by Liquidforce, Jun 10, 2019.
  1. Liquidforce
    Liquidforce Light Load Member
    273
    287
    Sep 27, 2016
    Savannah GA
    Seen a couple of trucks running 20 ft as doubles in GA/FL, similar to a fedex style setup but with normal tandem axle port chassis and a dolly.
    Whats the legality of that? we are talking 8 axles.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    They can pretty much go anywhere with anything that will fit inside each pup. Provided there is no prohibition against doubles etc.
    There is nothing much to worry about legally. Now if you can get twice the pay pulling two trucks.. /tease
  4. Liquidforce
    273
    287
    Sep 27, 2016
    Savannah GA
    Ok, so whats the weight rating then on 8 axles? or 9 axles if you run two tri axles and no dolly.
  5. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    The only combination that allows two triaxles with no dolly is a Michigan B train.
    It is better to put up a picture of the exact truck we are dealing with here. There is a range of possibilities with the Weight formula.
    S.V.Buyck Thanks this.
  6. Liquidforce
    273
    287
    Sep 27, 2016
    Savannah GA
    This chassis. With another tri axle. Obviosuly not legal in GA/FL then
  7. okiedokie
    okiedokie Road Train Member
    13,862
    109,806
    Jun 13, 2011
    PNWET
    Looks like a B train set up.
    S.V.Buyck and p608 Thank this.
  8. Liquidforce
    273
    287
    Sep 27, 2016
    Savannah GA
    This one is a b-train style, the ones Ive seen in FL/GA are fedex style with a dolly/convertor. No way to run a b train outside of Michigan/Canada obviously?
  9. wis bang
    wis bang Road Train Member
    3,454
    4,098
    Jan 12, 2011
    Levittown, PA
    I used to receive 20's filled with Styrene Pellets in a huge bag. A Canadian carrier brought them to NJ from Halifax and half of the chassis were the extendable tri-axle 'B' train. The all came in single but the empties went back doubled
  10. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    B- trains are legal in several states, maybe all states that allow doubles, at least RM doubles.
    B-trains are even legal here on some roads that doubles aren't.
    okiedokie Thanks this.
  11. okiedokie
    13,862
    109,806
    Jun 13, 2011
    PNWET
    That's right starmac. Pulled 38 ft. B trains in pnw, chips, flats, cans. Handle good, loads well and can back them up.
