Purchase check: dyno test or oil sample?
Discussion in 'Ask An Owner Operator' started by DechkoTzar, Aug 19, 2020.
  1. DechkoTzar
    DechkoTzar Light Load Member
    70
    28
    Apr 26, 2015
    What do you find more reliable way to check a used truck before purchasing: dyno test or oil sample?
    If dyno test: what are desirable results of the test?
    If oil sample check: how to read the results and what information would make you decide to proceed with the purchase or retreat?
    kimbosa Thanks this.
  3. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    They change the oil, dyno wont tell you much, drive, have another mechanic look at it, look for blow by start the truck open the fill tube for oil see how much smoke comes out, get maintenance report, any maintenance recipes
    DechkoTzar and kimbosa Thank this.
  4. Ridgeline
    22,721
    123,347
    Both, plus a blow by.
    Blowby is only tested with the truck running under maximum load.
    The dyno operator will tell you the tolerance of blow by. Depending on the age, you should take off the list any truck making less then ~75% rated HP.
    DechkoTzar, kimbosa and Speed_Drums Thank this.
  5. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    rigdigreport.com like a car fax for cars only for trucks. Also tell the dealer not to change the oil until you have had ability to get a sample for testing.
  6. kimbosa
    kimbosa Medium Load Member
    524
    351
    Jul 4, 2011
    lufkin texas
    NOW THATS A COOL SITE!!!!! THANKS MNMOVER
