I know there's been there's been thread's on this shop,but does anybody know if this shop is still worth patronizing.
Never been to this one,and i'll be through there tommorrow,looking to get my receive on my cobra looked at thanks.
Q5 In Wisconsin
Discussion in 'CB Radio Forum' started by Finfn1372, Jun 30, 2019.
They are among the better shops out there.Finfn1372 Thanks this.
Think i'll get Rick at the ta in Gary to do it,been hearing good things.
@rabbiporkchop what do you think will perform better,a 4ft skip on a spring ir a browing28 antenna thanks. -
A skip..Buy taller instead of a spring..
rabbiporkchop and Finfn1372 Thank this. -
The only problem is my perch sits at 8ft6in.
Sorry 8ft9in -
I got a 102" on a 10" shaft...Faster i go the taller it gets cause of the bend so when in ny goin across the cross bronx i slow down..
Finfn1372 Thanks this. -
I would get rid of the perch to,hate those pos...All the strain is on one bolt hole...If you lean the ant foward some then you loose the height at lower speeds but at higher speeds it will bend straight up n taller....Finfn1372 Thanks this.
Yeah I've got the browning at a slight lean.
Don't care to much for the perch either,but I can't run it through the mirrors at this time. -
Gotta geat creative and find another solution then but i ment the perch more so than anything..Depending on th trk there might be a 2 bolt attachment mount....Stronger and will help with grounding..
How do you expect him to bolt it onto his Volvo?
I don't think either one will work very well the way you're planning on attaching it to the vehicle. I would never use a Browning antenna under any set of circumstances due to how they're constructed and the problem with corrosion from road salt. I guess that leaves the 4-foot fiberglass antenna as the only other choice between the two choices.Finfn1372 Thanks this.
