Qualcomm Macros - need advice
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Jcdixon, Jul 31, 2013.
  1. Jcdixon
    Jcdixon Bobtail Member
    33
    6
    Jul 9, 2013
    Salado, TX
    I am a new OTR Trucker, I'm a trainee right now and the Qualcomm macros look complicated and seems like a lot to learn. Does anyone know of an easy way to learn them? Any help is appreciated
  3. skootertrashr6
    skootertrashr6 Medium Load Member
    639
    6,942
    Jan 4, 2012
    Pueblo, Co
    Depends on what company you are with, macros that one company uses isn't always the same as what a different one uses. Once you start doing them over and over you will start memorizing them. On the messaging part of the Qualcomm it will have your inbox, outbox and compose, under compose it has all you macros and description of each. Make a list of the ones you need to do on each load, or daily and once you start using them multiple times you will get it.
    Milo161 and Jcdixon Thank this.
  4. slim shady
    slim shady Road Train Member
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    Your company should give you a index type card with all the macros and a definition of what each is for. It'll become easy as time goes by.
    Sent from my RM-845_nam_vzw_100 using Board Express
    Jcdixon Thanks this.
  5. Jcdixon
    33
    6
    Jul 9, 2013
    Salado, TX
    CRST Expedited is who I'm working for. I was given a list of macros to learn. If they are on the screen for you to use when you need them, then you shouldn't have to try and memorize them right away, right? I've heard that it takes people a while to learn the Qualcomm system anyways, I don't know how true that is but if it is I could see why.
  6. slim shady
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    Yep they're all on Qualcomm its just a matter of remembering the number associated with each macro. There's way more macros than you'll ever even use
  7. NavigatorWife
    NavigatorWife Road Train Member
    2,937
    2,081
    Apr 30, 2012
    Cental West, AL
    Most generally the main ones will be the number for the shipper(arrival and loaded), receiver (arrival) , mty at receiver, a dropped trailer, new trailer p/u. ETA and PTA
    They may have one for a fuel request, breakdowns, survey of a company, directions to shipper or receiver
    And there may be some you will never have to use. But it is always better to be familiar of the ones you don't use. You can write down the numbers of the main ones with a brief description of them. The cheat sheet is a help. A lot of time is used to put in the correct info on the right macro, so you don't want to have to hunt them down.
    Qualcomms can and do go down and if you don't have this info written down you may chance not knowing where you p/u or deliver too. It is a good idea to have a notebook of some sort, I would recommend a spiral one, I pretty much use one side for each pro for husband;
    Write down the pro order number
    Any other purchase order #, or pickup # provided by your company
    P/u date and time
    Company name and address, city and state
    Delivery date and time
    When loaded write down the trailer number, weight, piece count (could be amt of pieces, pallets), BOL#,
    Write down any other pertinent info you might need such as a scale ticket or lumper fee. A macro for customer dircections should be one thing available to you and this may have the exit # listed, preferred road to customer, if they have overnight sleeping sometimes, etc. Sometimes the road info may be for a different direction than what you are driving in from, it is just a help is all if you can use it to correlate the safest way into a place.
    If using a route solution provided by the company go through and write all those roads down, either in a column or row. If you are company drivers in most companies it will be the shortest route on cowtrails that you get to go on and some roads maybe hard to pinpoint on a map. If you are lucky sometimes they may list a city you can use.
    Write down where your fuel stop is and what hwy and exit #, Etc.
    It is good to google the map, you may have to adjust it to their route. You can zoom into the businesses and see what the layout is. Google sometimes lies though and tells you a building is on the left or right and it will end up being on the opposite side, or somewhere else even. London, KY area is one that has things messed up real bad.
