Quest for mpg
Discussion in 'Volvo Forum' started by Helowrenchturn2, Apr 23, 2013.
  1. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Hello all, first post here. I have an 05 780 with d12d. Have replaced cac, boost sensor and turbo avg 6.2 mpg. This is what I'm thinking, gutting the preheater on the intake side to increase air flow as well as eliminating epg and restrictor in s-pipe and coming directly off turbo with exhaust piping to eliminate back pressure. Also installing full flow muffler. Thoughts or concerns?? Input greatly appreciated!
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    how do you drive it? When's the last time you checked your tire pressures?
    What's your trailer to cab spacing?
    Just a couple of the things I can think of that would make a bigger difference first.
  4. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    I've had good luck with Airtabs. What kind of trl and weight do you haul? Where are you located? Are you figuring the milage by dividing miles driven since last fillup,by gallons required to fill, or just going off the computer? I like the full flow exhaust idea, not so fond of removing the preheater, but hey,your truck
  5. Helowrenchturn2
    484
    140
    Apr 23, 2013
    i run mainly mid atlantic and southeast, alot of rolling hills for the most part and my weights are all over the place but more times than not it's in the 35 to 40k range all dry box. my trailer gap is as close as i can get it and tire pressures are checked daily. i run 115 in the drives and 112 in steers, a little rougher ride but i understand the higher pressures reduce the chance of a failure and reduce rolling resistance. all of my calculations are done on paper because there are too many variables in the system to go by the dash readout, but i will say that the numbers are usually within .2. i had the preheater apart 2 days ago just to see what the inside looked like, wish i had taken pics to share. there is an electric coil that takes up approx. 20-25% of the space. i was just figuring that if i gutted it then it would allow for better air flow, same principle as reducing exhaust restriction. i dont really need a preheater, i've had 2 other trucks both with detroits and neither had anything like that. never had a problem with cold weather starting. i believe it is intended for those in the super cold climates such as up north and the scandinavian countries that routinely see sub freezing temps, either way its optional equip IMO.
  6. MNdriver
    7,985
    4,372
    Feb 24, 2012
    Dice gave the comment he checks his brake drum temps for a hanging brake.
    I found two today that were 25-30° warmer. They are gonna get closer inspected.
    My trailer gap is 30".
    Last week I ran Killem biocide in my tank too. First filter plugged in 300 miles. This filter is doing much better.
  7. eeb
    731
    268
    Mar 24, 2013
    Cool, let us know how it works out.
  8. Helowrenchturn2
    484
    140
    Apr 23, 2013
    I've never thought of that, have to give it a look see!
  9. MNdriver
    7,985
    4,372
    Feb 24, 2012
    Didn't measure actual strokes, but the brak-chek indicators I use were quite a bit less on the two with increased temps.
    Backed em off, applied the brakes a couple times and rechecked and all the brakes are are now about even.
    Will be interesting to see how it goes tonight.
  10. Jetsr6
    Jetsr6 Light Load Member
    131
    46
    May 20, 2011
    Mechanicsville, VA
    Slowing down is the cheapest way to save on the flat. Rolling hills i go faster down then let off some going up and roll over the top. Kinda hard to explain. But thats what i do up here in PA and seranding areas. You could try a fleet-air filter $300 too.
  11. Helowrenchturn2
    484
    140
    Apr 23, 2013
    That's what I do now and keep my avg cruise speed right at 60...I'm just kinda brainstorming trying to come up with a few ideas to improve mechanically.
