Question: 55mph in CA and a tag axle
Discussion in 'Trucking Industry Regulations' started by gkmissingca, Oct 26, 2019.
  1. gkmissingca
    gkmissingca Light Load Member
    102
    29
    Feb 18, 2017
    CA states that any vehicle with 3 axles or more cannot go over 55mph. What if you have a tag axle that can be raised when not needed. Would that count?
  3. Ffx95
    Ffx95 Road Train Member
    1,370
    2,635
    May 18, 2017
    Knowing commifornia they probably count all axles on the truck regardless if they’re in use or not. Also I believe they go by axles or a certain registered vehicle weight both count. So even if you’re bobtailing with a single screw tractor you still have to adhere to the 55 speed limit.
    Bean Jr., gkmissingca and x1Heavy Thank this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    You best consider that is going to be a axle.
    Call your states's DOT board or Commercial Enforcement with that question before anyone has to write you up for not knowing for sure.
    Being CA, I would call it a Axle.
    gkmissingca Thanks this.
  5. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    That would be called a lift axle. Would it not?
    That's the way I'm interpreting it, anyways.
    Lift axle. Not needed when empty.
    Drop axle. Needed when overweight.
  6. snowwy
    20,612
    13,333
    Jul 6, 2009
  7. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    Ahh come on man. You no the answer. But sure go ahead and try to get technical. Maybe when you take the ticket (you will get ticket) to court. The judge will agree with you.
  8. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    i thought that was state wide anyway
  9. MGE Dawn
    MGE Dawn Road Train Member
    1,098
    2,294
    May 19, 2019
    Vancouver, WA
    How to answer any question about CA laws in a nutshell: ask yourself what the single most inconvenient interpretation would be for you. The answer to that question is also the answer to your original question
    TokyoJoe, AModelCat and x1Heavy Thank this.
  10. Knucklehead619
    Knucklehead619 Medium Load Member
    556
    664
    Mar 11, 2014
    Flyover Country
    CVC 22406 (a) states “No person may drive any of the following vehicles on a highway at a speed in excess of 55 miles per hour:
    (a) A motortruck or truck tractor having three or more axles or any motortruck or truck tractor drawing any other vehicle.”
    Your truck HAS 3 axles therefore you can go slow like every other trucker in CA.
  11. Powder Joints
    8,019
    8,482
    Sep 25, 2007
    Rosamond, SoCal
    According to CHP at the Tehachapi scale, if it is lifted, not touching the road, then you don't count it. 2 axle with a 3rd lifted is counted as a 2 axle. But if it were my money I would keep it under 60.
