When i turned off engine, ac blower and headlight should be off as well, but now still on, have anyone know what s the problem, is ignition switch?
question about 2011 volvo 670 ignition switch
Discussion in 'Volvo Forum' started by willu1974, Apr 10, 2015.
Hi, The ignition switch is controlling power relays (70 amps) (3 total) 2 Ignition Power relays and 1 Accessories Power relay if your truck has not been modify it look like you have a defective Power relay or ignition switch problem.
I suggest to you have a look under the cover (where is the cup holder) there a sticker to identify the components (relays and fuses) look for relay name PR1-PR2-PR3 those relays have 2 large legs and 2 standard legs because they are 70 amps rating you can swap them to figure out which one is defective.
Ben -
I forgot to ask you, is your engine turn Off when you turn the key at Off position ?
Right, at off position. I found problem, like u said is ignition, thx
Brother we have same problem ..could u pls tell me what u did.thanks
Yes please share to us how you fixed that problem. I’m in the same dilemma. Tnx!
His solution was he replaced the ignition switch.
