Question about Amazon Relay
Discussion in 'Ask An Owner Operator' started by Newtrucker123579, Jul 4, 2023.
  1. Newtrucker123579
    Newtrucker123579 Light Load Member
    70
    10
    Feb 3, 2023
    Hi everyone, I have a question about Amazon relay. Does Amazon Relay allow you to take one route consistently or constantly have the loads to support that route. If I’m being unclear an example would be out I wanted to run a route from ga to Tn daily would I always be able to find a load back to Georgia in the same spot? Thank you so much!
  3. Gliding ProStar
    Gliding ProStar Heavy Load Member
    860
    6,132
    Nov 12, 2016
    Waxahachie, Texas
    I do not haul for Amazon Relay nor do I pull a dry van but as a rule of thumb I would never rely on having a return load to the same city or town on a daily basis. I would expect there to be several days where a return load was not available. Hopefully someone with Amazon Relay experience will chime in and provide you with some insight.
  4. rollin coal
    rollin coal Road Train Member
    13,627
    28,010
    Mar 29, 2008
    TN
    ATL to Nashville and the reverse is a popular lane. Which means it usually pays garbage rates. Sometimes the TN to GA is ok and sometimes the opposite is. But more often than not, everybody wants those loads. Getting those from Amazon adds a whole new level of stink to already poor rates. Don't waste your time with Amazon. They will grind you up and use you for nothing.
