Question about an inverter?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Batman13, Oct 10, 2021.
  1. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    I couldn't find a thread for my question..so here it is...So I have a 2000watt inverter..its been giving me a problem..I can use a TV, PS4, and phone charger and it works fine...but whenever I try to use a single portable burner..it starts beeping loudly and says LUP on my inverter..I dont think its my batteries..but does anyone have any input on why its acting up and what to do?? Any info helps..thank you!
    Edit...it started smoking/sparking like a week ago from the ground wire..its been hooked up this way and has never been changed for a year now..so I dont know why it would start like this out of nowhere..
  3. Dino soar
    Dino soar Road Train Member
    4,834
    27,114
    Dec 8, 2017
    The first thing is, you have a circuit breaker or a fuse near the battery for the line that runs up into the cab right? So that your truck doesn't catch on fire right?
    It has not tripped the circuit breaker?
    Second check all of your connections at your cables and check the cables themselves. Take all the terminals off and make sure they're clean and they have a good tight connection. Make sure nothing has rubbed or is shorting out. Check whatever plug that you are using to the Burner that wire isn't having problems.
    Are any of the cables or wires hot to the touch?
    If all that checks out maybe you should try another Appliance to see if maybe that burner is defective or having a short,
    I suppose your inverter could be having problems, but if you see arcing at the ground cable, my real thought would be that you are having a connection problem or a cable problem.
    Whatever it is I would stop and fix that immediately.
    Batman13 Thanks this.
  4. Batman13
    110
    45
    May 20, 2020
    No it hasnt tripped it...when using the PS4 I had the tractor off...and the PS4 was super hot to the touch and shut off..when turning tractor back on..it worked with no problems...also about 6 months ago 2 outlets on the inverter stopped working and only 1 outlet works now..
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    If it’s not a pure sine wave inverter there are some items it will not run.
    I bought an induction cooktop, it would not work on a modified sine wave ( most standard inverters) inverter.
    Snailexpress, Batman13 and Dino soar Thank this.
  6. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,643
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    You need someone with electrical expertise to look at that truck ASAP, before it burns to the ground. It sounds like the 12v cables are in bad shape.
    Hammer166, Snailexpress and JoeyJunk Thank this.
  7. Anywhichwaybutloose
    Anywhichwaybutloose Light Load Member
    160
    267
    Jun 24, 2017
    LUP is a Low voltage code. Are you running the inverter just off the batteries?
  8. Batman13
    110
    45
    May 20, 2020
    Yea I have the inverter connected to the batteries...but half the time the rig is on..the voltage on my gauge shows nothing wrong..and I have no problems with rig turning on..
  9. 86scotty
    86scotty Road Train Member
    4,906
    13,591
    Aug 27, 2017
    Appalachia
    The most important question hasn't been asked. How big are the cables (what gauge) and how long is the cable run?
    Also, a TV, game system and chargers for portable electronics use very little AC power. Anything like a microwave, hot plate, toaster oven uses TONS of AC power. We're talking huge difference.
    If you are trying to use that burner without the truck running then there is your problem but a bigger problem is not knowing how your inverter is wired or what the power needs are of the things you're using.
    You are playing with fire, literally.
    Batman13, uncleal13, flood and 2 others Thank this.
  10. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Best answer.
  11. Hammer166
    7,669
    28,172
    Aug 18, 2007
    ~8600+' and loving it!
    The heat generated by the arcing isn't doing the inverter any favors, either.
    Batman13 and lilillill Thank this.
