Question about hauling Urea.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Sturgill, Aug 28, 2020.
  1. Sturgill
    Sturgill Bobtail Member
    16
    8
    Feb 27, 2020
    Howdy, there is a haul from Augusta, GA to Moscow , OH. Has anybody ever hauled Urea? What type of trailer? It pays $60 a ton. I’m just trying to get info and understand what type of equipment I might get.
    Thanks in advance!
    Sturgill.
  3. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    Google urea and go from there.
  4. Numb
    Numb Crusty Curmudgeon
    4,335
    10,299
    Jan 30, 2012
    Charlotte, N.Carolina
    edited because my question was dumb. :confused:
  5. LoboSolo
    LoboSolo Heavy Load Member
    737
    4,267
    Jun 21, 2013
    Highway 20
    Around here, it comes into feed plants in grain hopper bottoms.
  6. REO6205
    REO6205 Road Train Member
    13,168
    60,500
    Feb 15, 2014
    California.
    I've seen urea hauled in pneumatics, bottom dump grain trailers, belt trailers, transfers and end dumps.
    The type of plant you're delivering to usually decides what type of trailer is used.
    intrepidor Thanks this.
  7. david123abc
    david123abc Heavy Load Member
    839
    784
    Feb 2, 2011
    Augusta, GA
    Are you sure it isn’t a liquid? The plant in Augusta loads a ton of liquid urea. I don’t recall hearing anything about dry products other than AN prill, but I’ve never dealt with the dry side so I’m sure they make other stuff.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    46-0-0 white round pellets, used for fertilizer.
    I hauled it just this morning.
    41,993 kgs = 92,578 lbs of it.
    Super B train hopper bottom.
    I've seen it done in pneumatic trailers, but takes hours to unload, I can dump in six minutes if the facilities are right. As it is I unloaded direct at a farmers, 45 minutes unload and sweep out.
    Cattleman84 Thanks this.
  9. Cattleman84
    Cattleman84 Road Train Member
    10,026
    71,612
    Nov 1, 2017
    The Sticks, Idaho
    Ive literally hauled thousands of tons of the stuff... Hopper bottoms is what I've seen hauling it the most often. But I have also seenbit haules in pneumatics and belt trailers.
  10. Long FLD
    Long FLD Road Train Member
    12,919
    54,223
    Mar 4, 2015
    What you haul it in depends on where you’re unloading. I’ve hauled it in a pneumatic because the place wasn’t set up for hoppers and I hauled some in a hopper today. Unloading a pneumatic isn’t a lot of fun because the urea will clump up if you start building too much heat.
    If the places you’re going have a pit then it can be hauled in anything that you can haul dry bulk in.
  11. Sturgill
    16
    8
    Feb 27, 2020
    Thanks guys for the info!
  12. wis bang
    wis bang Road Train Member
    3,461
    4,109
    Jan 12, 2011
    Levittown, PA
    sounds like a pneumatic with bottom drop hopper "T"s would be quick over a pit...
    RockinChair Thanks this.
