Question about PC
Discussion in 'Questions From New Drivers' started by Canadianhauler21, Sep 23, 2020.
  1. Canadianhauler21
    Canadianhauler21 Heavy Load Member
    865
    1,643
    May 15, 2017
    Many drivers in my company have different ideas on what you can and can't use PC for. I'm going to post a few examples and you guys tell me if they are legal or not.
    1. Arriving at a shipper with 4 hours left on the clock, you go off duty and and leave the shipper with 2 hours on your 14 hour clock. You go into PC to get to a truck stop/rest area that is toward your final destination. What if you use it to go a truck stop away from your final delivery?
    2. You can't find parking late at night so you use personal conveyance to find a parking spot.
    3. You use PC from a truck stop to go to a shipper.
    4. You pull into a shipper with 5 minutes left on your 14 hour clock. You use PC to drive around the yard since you are out of time.
    I'm pretty sure all of these are illegal but I just want to make sure and what do you do in a situation like #4?
    truckdriver31 Thanks this.
  3. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    3 is. 4 might be. 1 and 2 are ok. PC can be used to get to a safe place. Which 1 and 2 describe.
  4. DrFlush
    DrFlush Road Train Member
    1,297
    2,707
    Mar 22, 2011
    Upstate NY
    Number 4 is a yard move, it is personal property so hos do not apply, the first 3 are not legal, unless in scenario 1 you are out of drivetime, then you have to go to the nearest safe parking area regardless of direction.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    #4 is easy. Use yard move.
    All the others are falsifying logs. You can read Personal Conveyance | FMCSA to get what is allowed. If the drivers cannot handle logging legal, then you might want to remove the option.
  6. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Nope. The only time you can pc to find a safe spot is if you run out of time at a shipper/receiver and there is no parking there.
  7. Canadianhauler21
    865
    1,643
    May 15, 2017
    ####, my eld doesn't have a yard move option. Any suggestions on what I should do in that scenario?
  8. Espressolane
    18,733
    117,494
    Have the system admin enable that option.
    kylefitzy and truckdriver31 Thank this.
  9. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Are you the admin? If so simply enable it (and disable pc for the drivers falsifying logs}. If you don't find the option you can contact support for your device.
  10. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    No. If you get to a truck stop and it is full you can as well. There are a few reasons.
  11. Blue Zombie Trucker
    Blue Zombie Trucker Light Load Member
    279
    681
    Nov 1, 2017
    This should get good...
    Speed_Drums, truckdriver31 and Kyle G. Thank this.
