Question about sliding tandems
Discussion in 'Questions From New Drivers' started by rpangburn, Aug 30, 2019.
  1. rpangburn
    rpangburn Bobtail Member
    41
    46
    Oct 26, 2016
    Need some advice everyone....been having a problem with these seed companies....3rd time I've scaled and slid tandems....last ticket shows..11,300 steers....33,360 drives..34,760 trailer axle....and now here's the kick...I'm at 1/8 of a tank of fuel.... Oregon to Tennessee...about how much does each hole give you?....any help would be appreciated....thanks for your time IMG_20190830_161011.jpg
  3. TravR1
    TravR1 Road Train Member
    3,695
    9,763
    Nov 9, 2017
    TX
    Should shift about 500 lbs. ?
    Call your dispatcher and tell them you need to fuel now so you can get a good weigh ticket.
    88228822, tscottme and rpangburn Thank this.
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Two holes should get you close.
    bryan21384 and rpangburn Thank this.
  5. rpangburn
    41
    46
    Oct 26, 2016
    I did fuel earlier....and meant to just fuel half a tank.... completely forgot and started cleaning windshield like routine and filled up 133 gallons....and I know that put me over weight...so am going to try again at half a tank...
    TravR1 Thanks this.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Are you at 1/8 tank, or 7/8 tank?
    Can you slide the 5th wheel up?
    Slide it up a notch, the the tandems up two.
    rpangburn Thanks this.
  7. rpangburn
    41
    46
    Oct 26, 2016
    Never have slid 5th wheel....would really like to avoid that if at all possible....but will if need be....the weights I gave was when I was at 1/8th of a tank...thinking if I slide tandems up 3 holes and run half a tank then scale I might be good
  8. MACK E-6
    50,027
    238,283
    Sliding the fifth wheel won’t lighten the trailer tandem. Moving it back one or two holes will.
    The bigger problem is the fuel situation. He’ll probably have to get fuel every 50 miles, if that. This is why you load with full tanks.
  9. rpangburn
    41
    46
    Oct 26, 2016
    I will from now on...that is for sure.. live and learn....
  10. GL1800
    GL1800 Light Load Member
    181
    142
    May 20, 2016
    You have to slide tandems toward your highest weight. Each hole is 300-450#, you can only move 2 holes or your drives will be over weight.
    Trucker61016 and rpangburn Thank this.
  11. rpangburn
    41
    46
    Oct 26, 2016
    Believe it or not...when me and the wife were in school,we were never taught anything about that....had to learn most of this on our own...asking other drivers at truck stops and on here....
