Question about stationary fifth wheels
Discussion in 'Trucks [ Eighteen Wheelers ]' started by musicmann2u, Mar 28, 2010.
  1. musicmann2u
    musicmann2u Bobtail Member
    29
    Buffalo, New York
    Hello Drivers: Can anyone tell me the pros & cons of having a truck with a stationary fifth wheel? I've always known them to be air adjustable but have never really had to move one. Am I asking for trouble in buying a truck with one?
    Thanks for your advice.:biggrin_2556:
  3. mitchtazz
    mitchtazz Road Train Member
    1,826
    503
    Sep 6, 2009
    Lake Wales, Fl
    aint neva heard of a pro of having one, normally companies that haul the same freight at the same weight (food grade tankers, fuel tankers, some dry vans) order their trucks with stationary fifth wheels cause they're cheaper, but if you're an owner Op you'd want the sliding fifth wheel because you'd want to be able to shift weight from your tandems to steer axle if the need arises.
    musicmann2u Thanks this.
  4. musicmann2u
    29
    Buffalo, New York
    Thanks mitchtazz for the fast reply, I worked for the big orange 10 years ago in a international cabover that had a air sliding fifth wheel, I always left in the same hole.
    But one time I adjusted it to try and balance a load when my trailer was full (big Mistake!) and pinched the air supply hose to the wheel causing it to leak, their I was at the Nashville Ta for three days! If I remember right they did not have the part:biggrin_25510:
    or they put me on the bottom of the list being a yankee and and a schneider driver.
    Won't do that again.
    Stay safe out there:biggrin_25515:
  5. Frenzy
    Frenzy Medium Load Member
    331
    186
    Mar 24, 2008
    Seattle, WA
    I generally pull light loads, so I set the 5th wheel as close to the cab as possible for two reasons:
    The first is that it improves the fuel economy.
    The second is that, IMHO, it makes it less likely to jackknife.
    When I get to a receiver that has a hole for a dock, I will set the 5th wheel all the way back and drop the air bags to get the trailer as level as possible. I have to pull pallets out as well as put return pallets of cardboard on.
    Thinking about it some more, there is one receiver that I have to pull the 5th wheel all the way back for to keep the bottom of the trailer from hitting the frame rails. That drop has a steep short ramp.
    Once in a while I will end up with a overloaded / misloaded trailer that I can pull legally if I have nearly empty fuel tanks and the 5th wheel set forward.
    Overall, for dry van, you are better off with a sliding 5th wheel.
  6. CAT700
    CAT700 Light Load Member
    106
    80
    Feb 2, 2010
    Hopkins MI.
    Hey :
    He said it right . better off with one than without.
    I just added an APU to my truck. A fixed 5th wheel and I would have been totally screwed.
    There are times when You will need it. :yes2557:
  7. 2hellandback
    2hellandback Heavy Load Member
    978
    237
    Dec 19, 2007
    Blackfoot Idaho
    Well my truck came with fixed, the first company i leased on to i never need an adjustable one. My boss on the second company said i needed one so i bought one from a wrecking yard rebuilt it and now $1500.00 dollars later it sets in the same spot never moved, just rusting away! :biggrin_25523:
    But hey its there if i need it right!
  8. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    lot of company trucks came with them, some because the loads are all the same, tanks, dumps for example. some because the fixed fifth wheels are cheaper and lighter. some because the company hauled lighter loads where shifting weight usually wasn't a concern . some because the driver's were guessed to be too stupid to move them. it is really according to what you haul. i suck the trailer up as close as possible for economy, when the weight allows. i have 3 trailers. each has a different pin setting, so i use mine quite often. i will state the obvious. it's easier to slide a sliding fifth wheel than to move a stationary one.free advice and worth every penny, johnny
  9. CAT700
    106
    80
    Feb 2, 2010
    Hopkins MI.
    Hey :
    The last post had a good point and I failed to say that. I pull company trailers. Many different makes. They do have different pin settings and I recently had to back up because the trailer would have hit the Fuel tank I added for my new APU. :biggrin_2551:
  10. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,652
    Nov 25, 2008
    Kellogg, IA
    There are a lot of dry van outfits that have stationary fifth wheels. They work fine. They do save about 250 lb, give or take, over a slider. When set right on the frame one would hardly ever go too heavy on a front axle. And the maintenance is lower on a stationary. Less parts, less fuss. I have a slider, but for most of what I do, it would not hurt me to have a stationary fifth. Guess it really depends on what one is doing as to whether they need a slider or not. When I was a company driver for a dry box carrier in the 90's, none of the trucks had sliders and I never had a problem not having one for the 9 years I was with them. That should tell you something.
    RubyEagle Thanks this.
  11. jtrnr1951
    jtrnr1951 Road Train Member
    Heck, I pulled reefer loads of 79K plus, with a stationary 5th wheel.
    Never had a problem, even out west...............in that state !!
    Cowpie1 Thanks this.
