Question for experienced drivers on a 13 speed fuller
Discussion in 'Questions From New Drivers' started by jakers, Feb 25, 2012.
  1. jakers
    jakers Bobtail Member
    10
    sutter, ca
    I am use to driving a autoshift truck that requires no manual shifting and has no clutch, but recently i just got moved to a 13speed. I learned how to drive on a super 10 a few years back so i am kind of familiar but i am having a little trouble going into low gears.
    I have always been taught to float and only use the clutch when starting from a dead stop.
    every time im in town and need to go down to a crawl I try to shift from 5th direct into 4th but i preselect and push the hi/low switch while im in 5th and try to go down into 4th, but i can hear a loud clunk in the tranny,why is that. i was always told not to switch from high to low in neutral always preselct is that true?
    how do you go go about shifting from high gears to low gears? do you preselect the high into low? do you have to clutch or what?
    the truck has over a million miles on it, so at first i thought it might just be a bad tranny but im not sure.
    How do you guys do it?
    Help would be greatly appreciated.
  3. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    Use the clutch and bring your RPM's up until it goes in gear smoothly with no grinding and or clunking.
    jakers Thanks this.
  4. jorlee
    jorlee Light Load Member
    197
    83
    Feb 17, 2007
    ND
    When does the clunk happen? When you preselect? When your bringing the lever through neutral? or When your moving the lever into 4th?
    jakers Thanks this.
  5. Kittyfoot
    Kittyfoot Crusty Ancient
    2,092
    3,056
    Sep 21, 2009
    Sorrento, Louisiana
    Maybe this will help.... [ame]http://www.youtube.com/watch?v=yrtfTovNohI[/ame]
    BTW, I'm having just the opposite experience. Our fleet is converting to automatics. We haul chemicals in smooth-bore tanks. In automatic mode the trans shifts harder than I do which results in more surge. Feathering the throttle doesn't help much and manual mode isn't much help either. Gonna take alot of experimenting to get smoothness back. PITA big time.
    I would take your 13OD in a NY minute anytime.... smoothest tranny out there.
    jakers Thanks this.
  6. Numb
    Numb Crusty Curmudgeon
    4,360
    10,384
    Jan 30, 2012
    Charlotte, N.Carolina
    the clunk is the hi/lo range changing.
    jakers Thanks this.
  7. Allow Me.
    10,788
    12,673
    May 28, 2009
    Rancho Mirage, Ca.
    OK, you're going from 5th direct down to the 'low side' without pushing down the switch. (the old trannys had a plunger). So, in essence, you're shifting from 5th direct into 10th direct,which is the hole for 4th, right ? Also, you can shift the high side from direct to direct or OD to OD, which is best to do while gaining experience.
    jakers Thanks this.
  8. lester
    2,957
    8,089
    Jan 2, 2012
    NW, Iowa
    sounds to me like your synchronizers are shot..
    jakers Thanks this.
  9. jakers
    10
    sutter, ca
    When i pull out from 5th with the lever pre selected into low, as i go through neutral it makes the clunk and 4th doesn't catch, no matter how perfect the rpms are. Some times i have to come to a complete stop and start back up. I have even been on a straight away and shifted down from top gear just to see what the problem is and as soon as i come down to 5th direct, the low gears don't wanna catch. but i never use the clutch since no one taught me how to double clutch because supposedly "its wrong".
    How do you guys down shift to low? Do you preselect it in 5th or wait to come through neutral?
  10. jakers
    10
    sutter, ca
    yes i do shift from direct to direct but only if im coming to a rapid stop like if its a short exit.
    But what do you mean by without pushing down the switch? I push down the switch in 5th right before i try to go into 4th, but there's a clunk and then 4th doesn't catch.
  11. jakers
    10
    sutter, ca
    I watched alot of videos on youtube but when i do what they do the clunking is still there.
    BTW i dont mind the autos when going through congested traffic, but i hate it in the snow, going over donner if you forget to put it into manual before starting up hill with chains on, the truck will gear up at low rpms and start lugging.
    But i would rather trust the auto than this 13 speed, i get screwed when going from high to low.
