Question on flatbed doubles and overhang
Discussion in 'Flatbed Trucking Forum' started by gkmissingca, Nov 24, 2018.
  1. gkmissingca
    gkmissingca Light Load Member
    102
    29
    Feb 18, 2017
    If I had flatbed doubles (28 ft), is overhang allowed i.e. over the deck of the front trailer, and over the rear of the 2nd trailer? Does that basicly fall under the max 65' rule? I was curious if the 65' applied only to the decks + tongue, or included cargo?
    cke Thanks this.
  3. Rugerfan
    Rugerfan Road Train Member
    7,807
    40,198
    May 3, 2011
    Redding,CA
    Wel hauling hay on a set of 28’ doubles it’s allowed so I’m sure it is
    cke Thanks this.
  4. Rugerfan
    7,807
    40,198
    May 3, 2011
    Redding,CA
    B3E8A4FF-3B16-41BD-8095-9B4EC380EB74.jpeg Had just a touch on this load and was legal
    SAR, Rollr4872, cke and 2 others Thank this.
  5. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    A-doubles or B-doubles? Because you can overhang B-doubles to your heart's content so long as the total vehicle length doesn't exceed 90 ft in Canada and 95 ft in North Dakota (the one state I know).
    SAR, MartinFromBC and cke Thank this.
  6. gkmissingca
    102
    29
    Feb 18, 2017
    Zeviander- mine would be a doubles
    cke Thanks this.
  7. beastr123
    beastr123 Road Train Member
    2,959
    24,286
    Jan 2, 2014
    Moose Jaw SK CAN
    Where do you run? All answers depend on that.
    The overall length laws in each state differ and that will be the main factor in most. There will be some that regulate "box length"as well and allow for more spread between to allow for more weight on each axle instead of grouping the center as a tandem group while giving you more overall length.
  8. gkmissingca
    102
    29
    Feb 18, 2017
    I tend to run AZ, NV, CO, NM. I haul cargo trailers and cars to return. Weight wont be an issue. Shooting for the extra 5 feet of deck and better turning radius. Might even save a little weight. Will be using electric axles
  9. Zeviander
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    These guides usually aren't hard to find...
    Arizona: Rules and Regulations (opens .pdf)
    53' semi-trailer, 28'6" full trailer, 65' full combination, 3' front overhang, 6' rear overhang
    Nevada: Trucker Guide (opens .pdf)
    "Cargo body length for a tractor followed by 2 or 3 cargo units cannot exceed 95 ft. Cargo body length for a truck followed by 1 or 2 cargo units cannot exceed 98 ft."
    Colorado: Trucker Guide (opens. pdf)
    " LVCs must obtain a special permit and may only travel on designated routes. LVCs, except the "Truck with Trailer" combination, have no overall length limitation."
    New Mexico: Big Truck Guide (opens .pdf)
    Doubles shown in diagram, must be 28'6" trailers or less, front overhang cannot exceed 3' and rear overhang cannot exceed 7'. There does not seem to be any specific restriction on total vehicle length for doubles (aside from trailers) and a single semi-trailer unit cannot exceed 65' total length.
    Reason for edit: Found the Arizona info
    SAR, kylefitzy and Tug Toy Thank this.
  10. Joel from Cargotecture
    Joel from Cargotecture Bobtail Member
    7
    I have a similar question- trying to ship a 45HC on a tilt-back 40 deck and wondering how much trouble I will have getting permission for it. 4' overhang off the back, and 1' off the front? Is there a front? Modified container, not empty.
  11. Joel from Cargotecture
    7
    I have a similar question- trying to ship a 45HC on a tilt-back 40 deck and wondering how much trouble I will have getting permission for it. 4' overhang off the back, and 1' off the front? Is there a front? Modified container, not empty. Alberta, Montana, Idaho, Washington is the route.
