Question regarding escorts and super loads
Discussion in 'Heavy Haul Trucking Forum' started by Hurst, Aug 15, 2015.
  1. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Picking up a 78k machine Monday morning in SC, its going to Houston Tx. Trying to do some homework before I get loaded so I know whats legal and whats not.
    Not 100% on weight yet,.. but according to booking sheet, I'll be somewhere between 138 - 140k gross, hopefully on just 7 axles.
    Trying to understand if thats considered a super load in SC. And if all loads over 130k gross need escort, or just over 12' ?
    Machine is a Komatsu WA 500-7. No bucket. Specs say machine is only 11' wide,.. so should be well under 12'.
    No permits yet,.. so I dont know how I will be routed. Guessing I'll be routed to 20wb and possibly to i10 at some point or stay on 20 all the way into Tx. Some of the routes these permits have had me on, had questioning their sanity.
    I'm going to look up Ga, Al, Ms and La now.
    Hurst
  3. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    Haven't hauled a WA 500 for a while but you shouldn't be that heavy. I would think it would be about 60,000 or a little under without a bucket and maybe 10' 6" wide or less (depending on the tires) with your truck which I think you said was around 60,000 empty you should be around 120,000 gross.
    Hurst Thanks this.
  4. clausland
    clausland Road Train Member
    1,933
    11,068
    Dec 5, 2014
    North Woods
    Likely depends on each State...............
  5. TripleSix
    133,587
    http://www.scdot.org/doing/doingPDFs/permits/OSOW_Guidelinesfor_movement.pdf
    j) Superload: Any load exceeding 130,000 pounds is defined as a superload. Superload routes are analyzed and approved by the Department’s Bridge Engineers. A Bridge Engineer analysis may take up to 5 business days. Axle weights that exceed 20,000 lbs on a single axle for non-divisible loads are reviewed by a bridge engineer for approval or denial.
    tsavory and Hurst Thank this.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
  7. TripleSix
    133,587
    They will probably route you 20w,285,85,65,10,12,10,210,10.
    saddlesore and Hurst Thank this.
  8. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I've never run a 500,.. so out of my element a bit. Not sure I've ever even seen one. When I was doing roadwork in Fla we used the 380 and 420. Loader did everything,.. they never sent in a grader. I did all of the subgrade with the loader,.. rough grade to finish grade, all of it right up until the pavers showed up.
    I was reading up on the 500's,.. and seems there is a difference in weight between the 500-6 and the 500-7. I'm grabbing the -7.
    I think you are right on the weight. Says operating capacity is 75 - 76k. I'm assuming thats with the bucket. Booking sheet says the machine I'm getting is 78k with out the bucket. Hopefully they have a scale at the plant I can get on.
    I'd rather err on the safe side,.. I dont want to leave the plant with out an escort if I end up being over 130k and if SC says thats a super load. I'm reading SC permit website and not clear on what maximum weight is before I need an escort.
    Only other state that I think I will need an escort is in Alabama. Ga, MS, La and Tx seem to be fine between 150 - 200k. I wont be anywhere near 150k this time.
    Hurst
  9. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Thank you,.. thank you!!!,.. I was afraid of that.
    Welp,. I might not be leaving SC right away.
    Let me ask you,.. with out the proper permit and escorts,.. I would have to drop the trailer at the plant. I would not be allowed to travel on any public streets,.. say to a truck stop with that load would I?
    Hopefully I scale under 130k with that thing. I'll make sure I'm under 1/2 tank fuel just in case its close. I'm still in Tn atm,.. 1/4 fuel right now.
    Hurst
  10. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Thats not too bad. Was hoping to avoid that long bridge after Baton Rogue,.. not the end of the world.
    Hurst
  11. TripleSix
    133,587
    Not trying to tell you how to run your truck, but I wouldnt do that half a tank thing unless I had 400 gallon capacity. You run from 30 minutes after sunrise to 30 minutes before sunset in SC and GA. You shouldnt have a metro curfew around Atlanta. But you dont have much time to make something happen. There's a scale 20 miles before you hit LaGrange,GA. Be mindful of sunset times before you cross that scale. Do it wrong, and you're going to get a ticket thats so big, you will have to take out a second mortgage to pay it.
    So, what I'm saying is time is extremely important. It takes too much time to be fueling up twice a day with a big load. If you can make it into Bama before evening curfew Monday, you can start out an hour earlier, and be in Houston Tuesday afternoon. If you cant clear that last Georgia scale in time, dont try it. Call your receiver in Houston and see if they have somewheres that you can park/drop your trailer. That way, you wont have to worry about the Houston curfew and stupid traffic.
    That also gives your company Wednesday, Thursday and Friday to book your next gig. $$$$$ for you.
