Question regarding idling
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Thetrashnoob, Jul 4, 2020.
  1. Thetrashnoob
    Thetrashnoob Medium Load Member
    304
    57
    May 30, 2019
    I know you don’t want to idle the new emessions trucks, but how bad would it be to idle the truck a few nights a month?
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    your truck or company truck
  4. Heavyd
    Heavyd Road Train Member
    7,833
    6,285
    Feb 4, 2009
    It is bad. You can run them, but you need to increase the rpm to about 900-1100. Regular idle is just too low and combustion temps are too cold which leads to carbon packing and cylinder wall washing out.
    MACK E-6 and 062 Thank this.
  5. Thetrashnoob
    304
    57
    May 30, 2019
    Mine
  6. MACK E-6
    50,322
    241,429
    Anybody know how to this on a 579 Pete with an X-15?
  7. Opus
    133,737
    Dunno about an X-15, but on a Detroit you turn on the cruse and advance the RPMs by pushing the 'resume' button. On the older ones, you advanced the RPMs with the 'accelerate' toggle switch.
    Frontman and MACK E-6 Thank this.
  8. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Its like @Opus said if its enabled in the ECM also most likely it will cancel the auto regen feature so I don’t recommend it with the cummins motor’s. Just let it idle and let the ECM do its thing.
  9. Brandt
    Brandt Road Train Member
    4,647
    6,421
    Sep 17, 2012
    I would not even worry about a couple nights a month. The newest emissions trucks will do automatic Regen when needed. That what Freightliner with Detroit engine do. Every 6 hours of parked idle time. It will do a 20 minute Regen automatically. It's nice how the new engines are doing that automatically.
    WildTiger1990 and Frontman Thank this.
  10. pushbroom
    pushbroom Road Train Member
    1,791
    7,405
    Sep 1, 2012
    No higher then 1000 on an x15. Above 1000 the turbo cant clamp down to make the heat required to regen.
  11. Roberts450
    2,237
    3,638
    Feb 6, 2016
    The other thing the cummins can do if enabled in the ECM is very the base idle from 600-800. On my 388 my idle was set at 700 but if I turned the cruise switch off using the set/resume you could very the base idle from 6-800 rpm but once you cycled the key switch it would go back to the normal set rpm. I would often bump to 800rpm and lock the fan on for better A/C and when using my 12v lunchbox to cook dinner and the truck would still do a regen if required in the middle of my 10.
