Question - Starting Engine - Slow Starts - FIX ?
Discussion in 'Volvo Forum' started by JerryD13, Jul 15, 2017.
  1. shogun
    shogun Road Train Member
    6,075
    72,164
    Jan 23, 2009
    Doing a regen
    Reading your post again, I would think it's ignition related if you can jump the solenoid and get the starter to crank.
  3. Will23
    Will23 Bobtail Member
    23
    Sep 19, 2013
    Ya I tried giving couple good hits didn't do anything
  4. Will23
    23
    Sep 19, 2013
    Ya I'm wondering if I should replace my ignition switch itself, anyway I can test it before replacing ?
  5. Will23
    23
    Sep 19, 2013
    Also at night time my truck is drawing power and looking voltages low power beeper goes on and I can't use interior lights or anything till I start it and charge it back up, going to be an issue once I have to use cab heater in winter, and a/c clutch is not getting power not sure if these are all related.
    KB3MMX Thanks this.
  6. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    Check overcrank protection on starter small plug under ground terminal if this has a broken wire or disconnected it will exactly what you are saying also check that you have power coming to firewall and also check make sure you have ground as well when u turn it's small wire on firewall solenoid u should get power
    KB3MMX Thanks this.
  7. nasriza
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    middle of cab behind ashtray panel on floor is the low voltage disconnect move both of the bigger terminals to one or replace the box and should be good
    KB3MMX Thanks this.
  8. Will23
    23
    Sep 19, 2013
    I don't mind that it's coming on, I just don't know why it's looking power at night for it to come on, most I'll do at might is have my phone on charger even when I don't charge phone it drops.
  9. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    The LVD in my old truck used to be sensitive like that.
    Drove me nuts sometimes trying to sleep lol.
    Thanks for the info on where it is and how to bypass it
