Question
Discussion in 'CB Radio Forum' started by Kwill361, Apr 26, 2020.
  1. Kwill361
    Kwill361 Bobtail Member
    I have a 2018 Freightliner Cascadia do I need to add an antenna for my CB or is the antenna in it now good enough?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Most trucks need a antenna set put in. Nothing fancy, just remember not to be taller than 13.6 with a small spring on the base.
  4. supertrucker79
    supertrucker79 Light Load Member
    135
    251
    Feb 4, 2019
    Pittsburgh, PA
    Your cascadia should have one built in. They aren’t great, but do function. Should be a power cord connection and the coax in the middle upper left console. You may need to remove the cover to find it. Most people don’t realize they have those connections behind that sunglass holder/cubby above.
  5. gentleroger
    gentleroger Road Train Member
    7,963
    21,802
    Jun 1, 2010
    If you want more than 1/2 mile range, yes you will need an aftermarket antenna.
  6. supertrucker79
    135
    251
    Feb 4, 2019
    Pittsburgh, PA
    I’m sorry was thinking of the 2013-2017’s. Should be right there in the upper middle in the cubby hole
  7. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Why the spring????
    Have to never seen those things flop around as you drive....Its worse than a limp mr winky after sex...
    On a low mount position like the last col models of cascadia get a top loaded 7ft fire stick or skip shooter....A hd wilson alumium stud and a mirror mount bracket for that model....
    NOOOOOOO spring bs.....
    Look my name on youtube and watch some of my vids if you need help..
