Question!
Discussion in 'Experienced Truckers' Advice' started by Boneyard6867, Jun 18, 2016.
  1. Boneyard6867
    Boneyard6867 Bobtail Member
    6
    I just started working for a local trucking company that runs end dumps hauling cooper concentrate. My question is, do i need to worry about the axle weights or just being under gross? I'm used to driving dry vans where axle weights is important, but there you can make adjustments if needed. I'm frustrated cause even if I'm under gross i still go over on the trailer. Please help me understand. Thanks
  3. okiedokie
    okiedokie Road Train Member
    14,678
    118,945
    Jun 13, 2011
    PNWET
    Then it's loaded wrong. Too much material in the rear part of the box. All trucks need to be loaded to specs. Get a light weight (tare) then subtract the gross. There's your net weight. The amount you can haul.
  4. STexan
    STexan Road Train Member
    14,963
    29,178
    Oct 3, 2011
    Longview, TX
    They probably will insure you're under their legal gross weight after you load. As far a end dump work goes, you have to put some faith and trust in the loader. Sometimes you might actually be over on and axle if you were to axle it but generally cops give end dump haulers some grace on axle overage if they catch them in a surprise check point.
    When hauling sand and gravel years ago, sometimes we'd have to shed a thousand pounds by carefully and slowly raising the bed and watch what falls out.
    Hopefully they will have somebody show you the ropes for a day and hopefully you won't deal with any state scale houses an a regular basis.
  5. okiedokie
    14,678
    118,945
    Jun 13, 2011
    PNWET
    New loaders have electronic on board scales. Its pretty simple. Your tare+net=gross. I drive 4 types of dump trucks. They haul 23-32 tons. Operaters get lazy. Keep them honest It's your license out on the highway. Make sure there's a tarp on the truck.
  6. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,649
    Jul 6, 2008
    Liberty, Missouri
    Just run around any scales.
  7. Toothpick1
    Toothpick1 Light Load Member
    152
    195
    Nov 26, 2008
    Canonsburg, PA
    Yes, you need to worry about axle weights because they are not truck-type specific.
  8. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    That is why I like a spread for end dumps. It allows you to go heavy on the trailer if in doubt. A good suspension gauge on the drives will get your weight where you need it. Usually most loader operator's will start at the front. Depending on what I am loading I will usually tell them to move back when I get 30k on the drives. You will learn quickly how to do it, and the difference in operators also.
