Questions on engine brake use.
Discussion in 'Questions From New Drivers' started by Woodys, Mar 16, 2018.
  1. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Well the minute I hit the jakes I've noticed pyro goes way down to below 500, maybe you have a retarder not a Jake that will raise oil temps if you leave it on for awhile
    Bean Jr. Thanks this.
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Well, I might be wrong. I thought the Jakes moved higher pressure air away from the pistons and let it decompress further down the line. I'm not a mechanic though, and I agree that extended use does seem to get the oil and water temperatures up a bit, and cause the fan to kick on more than driving on flat ground.
