I got a 2010 Freightliner Cascadia dd15 the truck has 691000. is it possible for the truck to start using oil past fifteen thousand miles on the oil change. it seems like if I go a mile past fifteen thousand truck starts using oil, won't use an ounce before 15k. could this be because of oil is breaking down or something else. I use a semi synthetic 15-40. what's your thoghts oil changes and the oil.
Questions on oil
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 3ARTransport, May 7, 2016.
Page 1 of 5
My last truck was a Cascadia w/dd15. I changed the oil every 50k until I put a million miles on it then every 35k. In all the years I may have added 4 gals of oil between oil changes ever. So if your loosing oil after 15k I would say you have a problem.
3ARTransport Thanks this. -
you see the problem I have with the truck is if I change my oil I'll be good for 15000 miles but if I go past 15000 miles truck start using oil if I change my oil today I should be good for another fifteen thousand miles just weird
Oil changes at 15k vrs 50k is like spending an extra $500 every 50k. I guess that's only .01¢ per mile but in a game of pennies it adds up.
Your right, it's a numbers game. I'm trying to figure out if anybody else had this problem with oil breaking down or is it is it a truck problem thank you very much for your reply
CJndaTruck Thanks this. -
I go about 20k with semi synthetic Mystik.
Actually that's normal.
Oil does break down and engines will start to burn it faster the longer it's left in the crank case.
IMHO 50k oil changes is just retarded.
I change mine at 15 thousand and it just starts use more the closer to 15 it gets.
Completely normal , you have nothing to worry about.
Some oils break down sooner then others tho , so you could try switching brands to see if it helps.
In my experience rottela broke down faster then delo so I stick to chevron delo 15/40Bean Jr., Diesel Dave, lester and 1 other person Thank this. -
I appreciate the answer, and you're completely right about delo vs Rotela. I noticed the exact same thing. thank you sir
You may think it's retarded but it is the recommended oil change interval on the DD15s that are driven more then 60k miles a year. As the OP is near the 100k a year mark he would fall into that category. His problem could be very simple like not using the manufactures specified oil.3ARTransport Thanks this.
Recommended or not , I would never run it out that long. But like I said that's just me. There is a local peterbuilt dealer here in town that I'm perty close with the shop Forman. They have been doing lots of inframes on ISX cummins engines at around 800,000 mark.
They open them up and just wore out.
They blame it on the extended oil drain intervals...........Bean Jr. Thanks this.
Page 1 of 5
