Questions on Re-Activating Authority
Discussion in 'Ask An Owner Operator' started by schmidt107, Dec 13, 2021.
  1. schmidt107
    schmidt107 Bobtail Member
    9
    Aug 13, 2010
    Good Morning could I get a little input on the process this takes to re-activate our old authority? It was voluntarily made inactive years ago, I don't know my DOT pin number either which it looks like I will need but can be requested. How do they verify that it is the old LLC picking back up the authority and not someone else as it will be a new address.
    I was thinking of just paying a company to do it so I wouldn't throw a wrench in the gears any suggestions on who to use? I found this company Evilsizor & Associates any feedback on them? Please give me a little feedback Thanks!
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    A couple of questions. How long has your Dot/MC been dormant? You have to update your information on the fmsca site every 2 years for your Dot, were you doing that? There is a possibility that they closed your Dot if you were not updating your information if it was a long period of time. If not you can request for the Dot pin & update your information. You can also call them (early morning is best) to explain your situation. I would try that first before paying someone for something you can do yourself.
  4. schmidt107
    9
    Aug 13, 2010
    It has been over 10 years and I know that the DOT number will be closed so I will need to request a pin and update my info. It just seems that maybe I should let some company do it that is used to working with them unless it is very straightforward.
  5. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    Join OOIDA.
    They will be able to answer all your questions and they will be able to reactivate it for you or advise you as to what to do.
    And afterwards they will be able to answer any questions you have about your authority or compliance or anything else.
  6. schmidt107
    9
    Aug 13, 2010
    Thanks I will do that we used to belong years ago too
  7. ibcalm19
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Yeah if it been ten years. You're going to need to apply for a new one
  8. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Mine sat dormant for 12 years and I was able to reactivate it.
  9. ibcalm19
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    He stated his address change & not updating. Were you updating it every two years? When I let my sit I still had to update.
  10. Oscar the KW
    12,247
    28,120
    May 19, 2011
    I never updated anything, and my address had changed too.
