Quick que?tion about a unique way of using a strap.
Discussion in 'Flatbed Trucking Forum' started by DeathByBanjo, Aug 25, 2014.
  1. DeathByBanjo
    DeathByBanjo Bobtail Member
    19
    13
    Aug 6, 2014
    Tyler, TX
    I had a load of signs to take to FL from AR.
    The nature of the load was two signs of different heights and lengths, and too long to place one in front of the other on the trailer. They are fragile, so they lag bolt it to my trailer, on four corners at the base, and have some angle iron set up, welded to the frame of the sign with some holes to run an I Bolt through for a direct tie down with 4 2" straps.
    They wanted me to run the straps connecting the inner angle irons / i-bolts on the shorter sign straight down (positioned off center of the trailer) THROUGH the boards, under the trailer and attached to rub rails. They said it was legal and they do it all the time, but I was uncertain and told em that crap wasnt gonna fly. They ended up welding some angle iron between the the two signs and I ran four straps for the longer sign, and two straps on one side for the shorter one, under the impression the angle iron connect made it one piece. It was solid.
    So my question is, is that stupid idea of running the straps through the boards legal? Im gonna go with no. Regardless, they were accommodating, and made it to where I felt like it was gonna be safe and secure going down the road.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Where are the pictures?
  4. xsetra
    xsetra Road Train Member
    5,198
    7,150
    Aug 21, 2011
    I was told a long time ago. Right or wrong not sure. The rub rail is not a rated point of attachment. I try not to use it for an anchor. I use the spools, stake pockets and the underside of the winch rail. Going thru boards, not sure what you mean. Where you put your straps, use wear protection.
    I use the rule. When in doubt, tie-down different or add more straps, chains. That gut feeling is usually right.
  5. 281ric
    281ric Road Train Member
    1,248
    809
    Oct 20, 2011
    TX
    Im a visual person... not sure what youre trying to say.
  6. notsonewb
    notsonewb Light Load Member
    180
    78
    Jul 29, 2014
    No way hooking to the actual rub rail is gonna fly , unless your trailer manufacture has a rating posted on the trailer for such an attachment , as far as between the boards I figure your deck has slits between the decking boards ? I would be Leary of this as well , it may very well be secure but , generally the deck boards are not to be used as they can split, splinter or come loose they are held in place with relatively small screws and are designed to support weight setting directly above , I saw a load once where a guy had a chain running over his outrigger deck board and tied to the d ring, when the load shifted , well it was ugly and dangerous, if I read what u said correctly , the board could lift or break, , why not just go over the rail and attach to under rail or better yet pockets, setting the straps wider will reduce the down force on a "fragile " load , also the straps are not required to be symmetrical , if the load is off center the straps will not bebut can still be safe and legal.
  7. walterjacobo15
    walterjacobo15 Light Load Member
    104
    91
    Aug 23, 2014
    Here and there
    Most likely it is (Given I pictured it right) but who cares?, the important thing is that you don't feel good about it.
