Radiator smell from bunk AC
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rocky The Expert, Dec 22, 2019.
  1. Rocky The Expert
    Rocky The Expert Bobtail Member
    7
    Dec 19, 2019
    What’s up trucking community. I’ll get straight to it I got a 2015 Volvo VNL 670 and my bunk/sleeper AC is giving this burning radiator fluid on hot surface smell into my sleeper everytime it’s on. I replace all the filters already the shop has even replaced the o rings on the heater core for bunk AC but I’m still getting the smell. Should I just run it for a while just to see if it just burn off leftover fluid from o ring repair or could it be I need to replace the whole heater core ?
  3. Lowboy456
    Lowboy456 Medium Load Member
    301
    146
    Mar 14, 2017
    I had some leaks under the hood the other day filling my cab with so much of that smell that your talking about. It irritated my eyes all weekend after driving in it on a Friday.
    I spent that weekend fixing all of them.
    I put 10 PSI on the cooling system and found 3 different coolant leaks.
    I found:
    1 - 2" stripped hose clamp
    1 - make do 1" oversized Oreillys hose oozing
    and the valve that shuts the water off to change the coolant filter was dripping even at 7 PSI
    Its packing nut needed tightening.
    Nothing was dripping on the ground in normal use but apparently some was seeping out and getting in hot places while running down the road.
    PE_T Thanks this.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Lift up the bed and get into where the a/c and heater cores are, then look for leaks?
  5. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    You might have a hole in your heater core. That happens after a few years of not circulating the water through there in the summer. It's always a good idea to run your heater for a few minutes every week in the warmer months just to keep the cores flushed.
  6. Lowboy456
    301
    146
    Mar 14, 2017
    Here's a pic of my home made coolant pressure tester. The quick coupler is used like a hose barb. I don't use that style of couplers. I didn't use the ball valve and larger fitting, I just keep it stuck on right there to keep it all together. I have a bunch of other fittings available as well for putting air and water at the same time to blast the inside of radiators and drain plugs on car radiators.
    I regulate my shop air so I cant get more than 10 psi. I could go whatever the cap is rated at. I think it's like 14 psi but 10 is a plenty. I tee'd into a small return line at the reservoir and didn't lose any coolant that way. I use a 30 Psi gauge for low pressure applications. Its always best to have a gauge that barely exceeds the desired pressure for testing. For instance if I had a 700 PSI gauge I'd never know if I lost 3 psi.
