radiator toast?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigdad7, Apr 17, 2014.
  1. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Ok have coolant dripping on left hand side of radiator dont see any lines there dont really see where it originates but its low if not bottom ...,this is a 01 century with a 12.7 detroit ....i am assuming a cracked radiator and have an apt with mechanic at home 400 miles away ....anything else that it could be hoping for cheaper newzO:)
  3. NRG
    NRG Light Load Member
    166
    46
    May 21, 2010
    Lloydminster AB
    Try "Radiator Stop Leak". Put a few bottles in there, depending on the gallon volume of your rad. That sometime helps if crack is not too big. Otherwise it's a new rad. :) "Detroit Radiator" sells and installs nice ones. You can get brand new one installed under a grand, with one year warranty. Or go with their best one, which includes 10 year warranty and goes for a little more then $1300 installed.
  4. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    You put it in overflow bottle or direct in rad
  5. RSQ20
    RSQ20 Medium Load Member
    rather that putting that gunk in the cooling system, why not run depressurized...
    ..... Philip
  6. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    I think we are there allready when i pulled the cap off there is no pressure i figure the rads toast anyways
  7. RSQ20
    I am not concerned with the rad, your CAB HEATERS, OIL COOLERS AND EGR COOLER would be my concern..
    Yes! you have no indicated pressure because it is exiting the rad, if you depressurize at the cap, there will be no residual pressure to push fluid out rad crack...
    Your call and $$$ my friend, I have spent my 2c worth..
    .... Philip
  8. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    No egr cooler cab heater on other side only thing.by leak is rad
  9. RSQ20
    Yes, but the coolant travels through the whole system...
    .... Philip
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Isn't your top rad hose on the left side? I've seen many leak and run down the inside of the tank. look close and check the hose clamps. If it's the radiator, then
    As far as stop leak, only if you really have no other choice. It can clog heater cores, oil coolers and make a slimy mess inside the engine. Getting home to save a few hundred may cost more more than that down the road. If you use it, have the mechanic fush the system and use new anti-freeze.
  11. NRG
    166
    46
    May 21, 2010
    Lloydminster AB
    No pressure if you pulled the cap off? Could be also 2 things. 1 is defective cap. 2 is your expansion tank baffle is broken and coolant flows into the overflow portion of the tank even when the engine is hot. There is a tube that comes out of overflow portion of the tank, could be dripping from there as well. If that's the case change both the expansion tank and the cap.
