Radio/Amp advice
Discussion in 'CB Radio Forum' started by rainmakerr, Mar 31, 2014.
  1. rainmakerr
    rainmakerr Light Load Member
    100
    25
    Mar 15, 2012
    Centreville, AL
    I have a Galaxy HD29 radio, not sure what it puts out on the low end off the top of my head but on high it puts out 40 watts. I have had numerous compliments on this radio and how it sounds but would like a little more power sometimes. I thought about buying another radio (Galaxy HD47) that puts out 100 watts; it has echo(which I want but it will be turned down, I have heard several people that had their echo turned down low and their radio's really sounded good, wouldn't have known they had echo had I not asked) but don't care for all of the other junk(roger beep, backlit, and etc..). I also thought about switching the radio to low power and use a 100 watt when I wanted. Any suggestions or thoughts?
  3. MsJamie
    MsJamie Road Train Member
    Props to you for wanting to keep the echo low. High power does no good when nobody can understand what you're saying.
    Timin770 Thanks this.
  4. Voltrucker
    Voltrucker Medium Load Member
    467
    133
    Sep 24, 2012
    West TN
    You could run a 2x2879 linear which will do about 350-400 at 12v. Far as echo goes, get a well known shop to add a echo board.
  5. M818
    M818 Light Load Member
    286
    147
    Apr 27, 2011
    Dallas, Texas
    2SC2879 :biggrin_255:
    SILICON NPN EPITAXIAL PLANAR TYPE
    2-30MHz SSB LINEAR POWER AMPLIFIER APPLICATIONS.
    (LOW SUPPLY VOLTAGE USE)
    • Specified 12.5V, 28MHz Characteristics
    • Output Power : Po=100WPEP
    • Power Gain : Gp=13dB
    • Collector Efficiency : '7 C = 35% (Min.)
    • Intermodulation Distortion : IMD= -24dB(Max.)
      (MIL Standard)
    http://www.rfparts.com/2sc2879.html
    gotta love those.
  6. Picklechips
    Picklechips Light Load Member
    103
    34
    Feb 23, 2014
    400 watts out of 2 2879s?
  7. rainmakerr
    100
    25
    Mar 15, 2012
    Centreville, AL
    only looking to go up to 150 watts max, don't want to be too much of a jerk.
  8. Voltrucker
    467
    133
    Sep 24, 2012
    West TN
    If 150 watts max, you could get a 1 pill linear. I'd also look into the rfx150 amp you can put in the radio. The rfx150 is made for people not wanting to run a lot of extra wires or doesn't have room for a external linear.
  9. rainmakerr
    100
    25
    Mar 15, 2012
    Centreville, AL
    How would this work if I use it with my radio on low power? Also, what is the thing about the crystal that is mentioned at the bottom?
    Texas Star Variable CW Transmitter - Mod V
    (1102)
    *1-2SC2290
    *100w+ output
    *14A fuse
    *Variable Power
    *Receive Pre Amp
    *Automatic SSB
    *v+, mod v+, amp, amps, amplifier
    *A crystal must be installed to determine the frequency of operation
    Or how about this for an amp?
    RM Italy KL 203P HF Linear Amplifier
    Frequency 20-30mhz, works on 15 meter, 12 meter and 10 meter ham band.
    • Mode FM-SSB-CW
    • Input power 1 - 5 W Max; Output power: 100 - 200 W Max, Preamp
    • Supply 12-14 Vcc
  10. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Too bad the bottoms aren't flat. Bad heat transfer unless they are prepped before installation for longevity.
