radio problems in winter weather
Discussion in 'CB Radio Forum' started by grasshopper13, Jan 23, 2012.
  1. grasshopper13
    grasshopper13 Bobtail Member
    7
    Erie, Pa
    The swr on my cobra29Ltd is sky high when
    its snowing out or when snow sticks to the antenna or coax. I run a 18' coax and a Wilson 2000 can anyone help me out with why this is happening and how I can fix it? Thanks
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    buy a snow shovel...knock the snow off the antenna....problem solved....
    next question.....
    AXE Thanks this.
  4. AXE
    AXE Road Train Member
    1,652
    689
    Jul 2, 2010
    Chandler, AZ
    Stay out of the snow...
  5. grasshopper13
    7
    Erie, Pa
    I heard that peaking my radio and adding a kicker would throw more heat and possibly keep the ice from forming on the antenna and coax. Is this true or just a bunch of bull?
  6. AB7IF
    AB7IF Light Load Member
    205
    103
    Jun 11, 2011
    Somewhere, Ar
    Only if you run a Skullcracka.
  7. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Yes....Thats true, but you'll need at least a 48 or 64 pill Amp...Any Amp that can get you over the 10,000w mark should work just fine...
    grasshopper13 Thanks this.
  8. SkyHawkTexas
    SkyHawkTexas Bobtail Member
    38
    8
    Jan 15, 2012
    Galveston, Tx
    If you could do something about this...... Then you would not be worrying about this..... Because you would be telling the man upstairs what to do.....
    About only thing you can do is knock the snow/ice off of it before you transmit.
    Yea,,, and with texas star, palomar, davemade, xforce.... pick any amp you like. But one thing I do know..... NO AMPS LIKE REFLECT.....
    FYI skullcrackas transistorized amps do not like anything above 1.2,,,, Above that and you are taking a chance of releasing the magic smoke....
    Dave, xforce, fatboy do not like above 1.3
    Most Texas stars.... Do not like above 1.5
  9. grasshopper13
    7
    Erie, Pa
    How much will a 48 or 60 pill amp run me? And is it something I can install or do I need a shop to do it. I live in Erie Pa and dolt know of a good shop close by.
  10. BOOTYMONSTER
    BOOTYMONSTER Light Load Member
    99
    64
    Oct 3, 2008
    RICHMOND VA.
    48 pill is about $4000
    figgure a few thousand more for the alternators , motor maul and extra batteries and you'll be set .
    JJD's idea about knocking the snow off is a whole lot cheaper , and a much much better idea IMO .
  11. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    If you have to ask......Buy the shovel.......or move to Florida...
