radio static goes away when braking
Discussion in 'Experienced Truckers' Advice' started by chp56, Feb 5, 2022.
  1. chp56
    chp56 Light Load Member
    150
    33
    Sep 25, 2011
    Barstow, Ca
    would that be a bad cab-to-frame ground?
    MOBee and Boondock Thank this.
  3. 201
    201 Road Train Member
    12,820
    26,400
    Apr 16, 2014
    high plains colorado
    Welcome,,to the Twilight Zone,,,sounds like a brake light issue.
    MACK E-6 and Boondock Thank this.
  4. Boondock
    Boondock Road Train Member
    1,198
    10,074
    Jul 20, 2019
  5. chp56
    150
    33
    Sep 25, 2011
    Barstow, Ca
    interesting-how so?
  6. tscottme
    tscottme Road Train Member
    It sounds like a bad ground to me
  7. chriskc
    chriskc Light Load Member
    173
    366
    Mar 31, 2013
    Kansas City mo
    Am/fm radio or cb radio?
    Boondock Thanks this.
  8. 201
    12,820
    26,400
    Apr 16, 2014
    HA! Got me, electrical always baffled me, but I think, maybe, when you put on the brakes, it helps complete a circuit, usually a bad ground. Run another ground from the frame to the cab, see if that helps.
  9. MACK E-6
    50,139
    239,524
    Yeah, this one makes zero sense.
    Usually with this sort of thing hitting the brakes would MAKE noise, not kill it.
    kylefitzy Thanks this.
  10. chp56
    150
    33
    Sep 25, 2011
    Barstow, Ca
    I believe that'll be it
  11. mustang190
    mustang190 Road Train Member
    2,895
    6,259
    Jan 18, 2011
    Florida Panhandle
    The problem with these new trucks is that all the electronics are integrated onto a single buss.
    Had a similar problem once in a Volvo, the radio was irritating to listen to. Ran the radio power wire straight to the battery buss, installed a fuse holder problem solved.
    tscottme and black_dog106 Thank this.
