Radio volume freightliner cascadia
Discussion in 'Questions From New Drivers' started by dboot01, Feb 2, 2024.
  1. dboot01
    dboot01 Light Load Member
    135
    225
    Nov 8, 2021
    So I just started a new job and my truck, even at max volume 30 is not that loud. Is there a setting I'm missing for louder speakers? I need more volume for Rush, Pantera, and Slayer!
    Magoo1968 Thanks this.
  3. Outtatheway
    Outtatheway Bobtail Member
    28
    53
    Oct 8, 2023
    ####ing slaaaayyyeerrrr!!!
  4. Freddy57
    Freddy57 Road Train Member
    1,731
    8,246
    Nov 29, 2013
    Mount Vernon, MO
    Those OEM radio's have volume limiters built in for "safety". I always just bought one at Walmart and swapped it out so I had full volume.
    Crude Truckin' Thanks this.
  5. JC1971
    JC1971 Road Train Member
    2,683
    9,818
    Jul 29, 2013
    Southwestern U.S.
    If you have an inverter, get a Bluetooth speaker. Your retard company can't mute your radio when you're in reverse, either.
    dboot01 Thanks this.
  6. dboot01
    135
    225
    Nov 8, 2021
    Slayer rulllleessss. Chemical fing warfareeee
  7. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,480
    Mar 18, 2021
    St Malo mb
    Check in bunk to see if it has a speaker shut off switch
  8. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,456
    6,861
    Oct 22, 2016
    North Dakota, Eh?
    And factory sucks. You you ain’t gonna rock out with the factory deck.
  9. Brandt
    Brandt Road Train Member
    4,626
    6,360
    Sep 17, 2012
    Make sure you turn up the Bluetooth volume up on phone. If the source is recorded low then it won’t be very loud. Some podcast are recorded with Low volume.
  10. tscottme
    tscottme Road Train Member
    Increase Treble EQ settings.
    Isthere a chance you are noticing hearing loss for the first time?
    77fib77 Thanks this.
  11. BillyBobFrank
    BillyBobFrank Light Load Member
    208
    388
    Nov 7, 2022
    I recommend getting a good quality headset instead. You'll be able to take calls and the sound quality will be better than the stock speakers one the truck.
