2004 Peterbilt 330 with a serial # ending in 830080.
There are 2 wires that go to the radio, one switched and one unswitched. The switched wire is in the fuse box next to my left foot. I cannot find the unswitched wire that is suppose to be connected to a 10 amp fuse. The wire number is "087" Can anybody give me a clue where they put the fuse???
radio wireing
Discussion in 'Peterbilt Forum' started by Barnbuilder22, Feb 7, 2018.
supermiller.com is where you will find your answer.
You can do anything at zombo.com
The cab harness is not listed for that truck. It does show 2 10 amp fuses for the radio however. The only fuse locations are by the left foot and possibly a few behind the speedo. The radio may have a fuse in the back of it.
In the kick panel the fuse may not be labeled as Radio, it may be acc or something else entirely. Go through all the fuses with a test light and check to see if any are missing. -
on the fire wall under the hood left side on mine
