Ramps and Curves
Discussion in 'Questions From New Drivers' started by farmerjohn64, Aug 12, 2020.
  1. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    Hi,
    What’s the best way to take ramps and curves? For curves if need be I slow down before I enter the curve and if I’m well under the speed limit I accelerate coming out of it; off ramps seem to be a bit of a problem for me because I don’t think I have the right plan of attack; I’m nervous about slowing down too much on the interstate for fear of someone running into my arse end, so instead I used to start slowing down just before and continue to as I’m exiting but I now see this was dangerous because going from 65 mph to let’s say 30mph isn’t an easy task when you’re about to run out of real estate; now I like to signal under half a mile if possible my intention of exiting, start winding down sooner and then take the exit. How do you like to overcome these obstacles?
    Best regards, John
    Coffey and 650cat425 Thank this.
  3. Chinatown
    Chinatown Road Train Member
    77,896
    185,151
    Aug 28, 2011
    Henderson, NV & Orient
    I use the turn signal when entering the interstate and then if I'm too slow after merging into traffic, I'll put on the emergency flashers until I'm up to minimum interstate speed.
    sirhwy, Tb0n3, Gutter and 12 others Thank this.
  4. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    I forgot to mention entering the interstate, but that’s a good idea; I always hammer down if the on ramp is straight, or after the curve so that I can slip right in
  5. MACK E-6
    50,105
    239,095
    I-83 in PA can be dicey for this sort of thing. You just have to do what you have to do. Just signal your exit way early and slow down as needed.
    That’s one of those situation where you can’t really go by the book.
    Brettj3876, Tb0n3, Gutter and 7 others Thank this.
  6. pavrom
    pavrom Road Train Member
    3,217
    7,422
    Apr 29, 2012
    NE illinois
    When i was driving bmw i never understood yellow 25-35-50mph suggestions on ramps and curves drifting in at triple of the posted limit :)
    They are exactly for truck driver and works well if you obey :)
  7. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    I got a call from safety awhile back about some sensor on the truck going off that trips when I guess you’re turning too fast, said I was doing good other than that, just trying to improve in that regard; reason why I’ve been nervous to slow down on the interstate is because I watched a truck riding another one’s arse, guy goes to exit slowing down too fast for the guy behind him to slow down enough and he got lucky because he changed lanes; I think what happened was the dude in front failed to signal in advance and the other guy following too closely
    650cat425 Thanks this.
  8. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    Lol dang it i was humble enough to come here for help and you run me through the back with a sword, jk; even though you were joking I’ll point out the posted speed limits are for regular traffic and not big trucks, just to show I’m not totally incompetent
    sirhwy, 650cat425 and Numb Thank this.
  9. Numb
    Numb Crusty Curmudgeon
    4,341
    10,309
    Jan 30, 2012
    Charlotte, N.Carolina
    I usually took the ramp speed limit as a rule for cars and would go slower, sometimes A LOT slower.
    tanker even slower.
    you can always take corners too slow, too fast just once.
  10. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    You're big. 4wheelers are small. People can see you from a good distance. Slow gradually and not rapidly. While signaling your intent. Should not have a problem.
  11. pavrom
    3,217
    7,422
    Apr 29, 2012
    NE illinois
    I did not joke ...when switching highways or going off highways there are yellow signs ... You better be slow than fast till you have a feeling what proper technic to use... I normally slow down mile before exit
