Ran outta Diesel
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cat nip, Jul 15, 2010.
  1. Cat nip
    Cat nip Light Load Member
    192
    10
    Jan 17, 2010
    Magnolia, TX
    ok... I know I sound like a rookie... but... If you run out of diesel is there some sort of secret to getting the fuel system primed back up? I put fuel back in the filters and it cranked for a second but ran crappy and died. Do I fill them up again and again without letting it start? dunno
  3. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Fill them up again then start pumping the primer while someone is turning it over.
    Your arm is gonna want to fall off when its over!
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    The easiest way on top of filling the filters up is starting fluid in the air intake. Pull the air filter out and have an assistant give it a couple second shot followed by a couple more shots if neccesary to keep it running. Don't overdue the spraying it as you don't want the engine racing. The fuel will prime in 5 seconds or so.
  5. dieseldon
    dieseldon Light Load Member
    155
    52
    Feb 14, 2010
    Detroit, MI
    Be careful with the starting fluid. It will work but don't over do it. You could wreck the engine. just a little dose.
  6. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    leave the starting fluid on the back shelf and put alittle extra effort into it. The best way imo...:biggrin_25514:
  7. T800
    T800 Light Load Member
    64
    Mar 23, 2010
    Calgary Alberta
    I second that Black Dog. just keep priming and opening the bleed screw until all the air is gone. It is not that bad once you figure out how to do it.
  8. black_dog106
    1,786
    1,666
    Mar 29, 2009
    MA
    unless it is a rental (penske,etc).In that case, who gives a sht...:biggrin_255:
  9. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    ...or if you have an ISX, just turn the key and wait for it to start. :biggrin_25525:
    This one has never taken more than five or ten seconds to fill the filters and fire up. Long way from the old days where changing filters was a major PITA.
  10. Les2
    5,150
    2,288
    Jul 25, 2008
    Are you talking about the bleed screw on the injectors?
  11. DDS
    DDS Medium Load Member
    519
    177
    May 20, 2008
    Toronto
    I take it we are talking about your MXS? If it does not have a hand primer, you need to get one. Best way is to loosen the fuel return check valve about three turns, this allows you to pump the fuel through the head and out to the return line without any resistance. Then tighten it back up and pump until hard and fire it it. Good luck
    rookietrucker Thanks this.
