Rand McNally tnd 740
Discussion in 'Experienced Truckers' Advice' started by michaelj123xx, Jan 4, 2020.
  1. michaelj123xx
    michaelj123xx Light Load Member
    111
    63
    Feb 11, 2013
    Hello I had bought a Rand McNally tnd 740 and when I plug the cigarette lighter in the truck today the red light won’t go on then I tried it in my car to make sure it wasn’t my truck and it still did the same thing. The usb cable works but has to be shut off for the charge. I got it on amazon brand new just seeing if it had happen to anyone else. Or if there is a way for it to be fixed without dealing the hassle of returning it. Thanks
  3. Espressolane
    18,717
    117,367
    The unit has failed. A known common problem.
    Your options are limited.
    If you are still in the time you can return it, then that would be your best option. The only other option is to have the unit serviced by the company.
    Good luck!
    michaelj123xx Thanks this.
  4. michaelj123xx
    111
    63
    Feb 11, 2013
    It just sucks should I even get another one or just get my money back I was so excited to get it then I wanted to thow it out the window lol
  5. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    The charging cables are cheap and fail often. When you say the red light isn't on, do you mean the light on the head of the charger? If that's the case either the fuse inside the charging head is blown, or your lighter outlet isn't working because that light goes on regardless if the other end is plugged into the GPS or not. There is also a little data port on the left side of the GPS unit that a standard cell phone charging cable works on, and the other end you can plug the USB end into your radio and it will charge the GPS unit.
    These things need to charge for a while before they will turn on. The internal battery doesn't last long, and if it has been sitting turned off for a few days, you'll need to charge it up before it will come on. I found this out the hard way. Once working, they work good. I've owned mine 2 years without any problems.
  6. mitrucker
    mitrucker Road Train Member
    5,496
    10,373
    Dec 15, 2010
    Lapeer, MI
    Wow. There is one that actually works. Simply effin amazing.
  7. SteveScott
    4,897
    16,809
    Nov 10, 2015
    The hardware sucks, but I like their software much better than Garmin or other manufacturers out there. The extended warranty is worth the investment.
  8. michaelj123xx
    111
    63
    Feb 11, 2013
    Yes the red light on the charger I checked the fuse in the charger it wasn’t burnt out and tried a different device in truck worked fine I just got it yesterday they said to return it and get another one or should I just continue using google maps I am a local truck driver manly drive in New England Just makes me mad it’s brand new
  9. michaelj123xx
    111
    63
    Feb 11, 2013
    I also tried putting it in my car same issue the red light would not turn on so it’s something wrong with the cigarette charger
  10. SteveScott
    4,897
    16,809
    Nov 10, 2015
    That's strange that a charger on a brand new unit wouldn't be working. Who was the seller on Amazon, a private company or Rand McNally? Sounds like you got a defective or maybe a unit that was already returned by somebody else. Send it back for a refund and buy another one at a truck stop that you can test before leaving the place.
  11. michaelj123xx
    111
    63
    Feb 11, 2013
    I called the said it was a third seller so I’m returning it today at kohels they said I can take it there so pretty happy about that or buy a new charger but I don’t want to spend another 20 bucks when this one should be working
