Random high idle
Discussion in 'Kenworth Forum' started by Gsxrrcr, Aug 13, 2018.
  1. Gsxrrcr
    Gsxrrcr Bobtail Member
    Hi! My truck randomly kicks the idle up to 7-800 rpms. It’s not doing a regen but does anyone know if this is normal or not? Thanks!
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    What year truck and what engine? How long does it idle up for? What is the normal idle rpm? How long are you idling before it kicks up?
    Oxbow Thanks this.
  4. cowboymagic81
    cowboymagic81 Bobtail Member
    10
    Sep 2, 2018
    My 2013 T660 does the same BS. Normal idle is around 550-ish, but will idle up randomly from time to time around the 750-800 mark w/increased engine oil temp. I had asked a mechanic this once before, and he claimed it's called "passive regen". Idk, but personally, it's annoying as hell. Hope you find out if this is normal or not, cause I'd like to know myself.
  5. J Rich
    J Rich Medium Load Member
    363
    380
    May 28, 2018
    Atlanta Ga
    I have a 2016 T880 with a ISX15 it does the same thing. It is the passive regeneration. Nothing to worry about and no way to stop it.
  6. Dave_in_AZ
    425,161
    It's the Cummins regen mode. It probably changes pitch at that time too.
  7. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
    Stop idling.
    Problem solved
