I recently had work done on my radio the range infront is about a mile I guess but as soon as the vehicle passes in the opposite direction I lose signal cannot receive on here could the problem be the antenna because the radio work fine at the CB shop. Model is cobra 29 Ltd classic and it's about 4 yrs old. only opened up 1 time just to replace the power cord.Thank you
Range and signal
Discussion in 'CB Radio Forum' started by RickDaDriver, Jul 27, 2016.
what type of truck. factory coax is crap.....plenty of people will reply to you. they need all the info. you can give them ........
Antenna system. Cobra 19 hears as far as my 2970 with the same antenna.
rabbiporkchop Thanks this. -
Who worked on the radio? I only know two guys that can make a radio hear well.. one of those guys is a part timer that works in Fontana California at CB radio store and the other guy is in Las Cruces New Mexico. If it wasn't one of those two guys I highly doubt the receiver was done correctly and you probably have lots of static in your receiver covering up all the weak signals out in the distancebored silly Thanks this.
