Ranger 2950CD blown finals cost
Discussion in 'CB Radio Forum' started by Sgonza101, Sep 8, 2019.
  1. Sgonza101
    Sgonza101 Light Load Member
    136
    28
    Mar 10, 2018
    Do you guys know how much they charge to fix the transistors in a ranger 2950CD?
  3. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    I know a guy that would do it for 30 bucks. It won't perform very well after he gets done with it though.
    DTB Radio or Q5 CB can fix it but the cost will be much greater.
    Sgonza101 Thanks this.
  4. Sgonza101
    136
    28
    Mar 10, 2018
    I was looking online and it's a two $6 part + labor.
  5. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    The parts are cheap. Labor can cost up to a 100 bucks an hour and replacing the finals isn't simply a matter of dropping parts in and soldering them in place since other adjustments have to be made to compensate for the differences in the new transistors.
    That's why I mentioned some guy over in Missouri that doesn't really know what hes doing and he would probably charge you 30 bucks to put the new parts in but he doesn't have a clue how to make any of the adjustments necessary to make it function at its peak potential.
    DTB and Q5 Would probably charge you at least a $100 to replace those components and realign the radio.
  6. Ridgeline
    22,732
    123,574
    A few thoughts ....
    Rabbi is partially right, but just replacing them will give you a radio. Getting it properly aligned will give you performance of the finals.
    The replacement of the finals are simple and if you have a mechanical ability, you can do it yourself.
    The more important question that needs to be address is why they went bad. Was it a bad antenna system or something else?
    rabbiporkchop Thanks this.
  7. Sgonza101
    136
    28
    Mar 10, 2018
    Bad antenna, high swr.
  8. Ridgeline
    22,732
    123,574
    Ok as long as you identified it, I've know people who blew finals, paid good coin to get them fixed only to have the radio end up blown finals within a day.
  9. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    a buddy did that, got a new general Lee and put it in his truck... 2 days later it was dead, sent it back, they replaced the finals, he put it back in the truck, the next day it died again, so he put his conex 3300 (same radio as the general lee) next day guess what happend...?
