Rate my setup
Discussion in 'CB Radio Forum' started by Bret1984, Aug 19, 2022.
  1. Bret1984
    Bret1984 Medium Load Member
    523
    829
    Mar 4, 2020
    Fort Worth, TX
    General HP 40W with dual Predator antennas 20220728_142334.jpg 20220819_170738.jpg 20220819_170702.jpg 20220728_153914.jpg
  3. Big Road Skateboard
    7,237
    41,218
    May 2, 2021
  4. Lennythedriver
    Lennythedriver Road Train Member
    2,422
    8,277
    Feb 14, 2020
  5. Bret1984
    523
    829
    Mar 4, 2020
    Fort Worth, TX
    The technician wasn't there today. He comes in tomorrow so tomorrow I can get the SWR's set on the new antennas. Even without the SWR's set they're already an improvement over the Browning coil antennas I was running. So after tomorrow I should have some reach.
  6. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    How did you discover this?
  7. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Is it necessary to tilt antennas forward that much?
  8. Diesel Dave
    9,770
    33,685
    Jan 20, 2010
    Hesperia, Ca.
    He’s trying to look “cool”……. I could never figure out the reasoning behind that also. I always figure, the taller in height, the better, but what do I know……
  9. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    There are valid reasons to tilt. One reason would be to achieve a vertical antenna at hwy speeds. Another might be for SWR reasons. In this case IMHO it looks excessive. Your radiation pattern suffers with every degree of tilt, and in this case it looks to be approx. 45 degrees
  10. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    With that much tilt, if your antennas don't stand straight up at highway speeds you may be losing effectiveness.
  11. Bret1984
    523
    829
    Mar 4, 2020
    Fort Worth, TX
    Yes, otherwise I lose them when I go under conveyors and stuff to load
