Ratio
Discussion in 'Ask An Owner Operator' started by teamscanada, Dec 7, 2023.
  1. Ridgeline
    22,752
    124,080
    then don't drive it.
    Seriously the engine size also matters.
  3. Mnmover99
    Mnmover99 Light Load Member
    248
    344
    Oct 22, 2022
    2.28 ratio with 22.5 low pro tires. Volvo 13 speed auto, run rpms 900 to 1200.
  4. Long FLD
    Long FLD Road Train Member
    12,958
    54,394
    Mar 4, 2015
    Was a 2011 designed to be downsped that much?
  5. teamscanada
    teamscanada Bobtail Member
    15
    Jul 21, 2021
    so lower the gear the lower rpm and better fuel miles
  6. Long FLD
    12,958
    54,394
    Mar 4, 2015
    You need to do some research on the specs for the Volvo engine in 2011. Find out the torque curve and the operating range where the rpm’s should be.
  7. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    Why are those your only options?
    The right truck for you is out there. Do the research.
