I've seen this as well when an engine miss is present. The engine miss is transferred to the trans by interrupting load on the trans and the mainshaft gears rattle and jingle.
rattle with engine under load
Discussion in 'Trucks [ Eighteen Wheelers ]' started by deereman6030, Sep 28, 2012.
Page 2 of 3
well crap! had the local mechanic ride in it he said bearing goin out but im leaning toward u all it makes most sense. the truck hauls grain for us and feed, ive bn battling this for 3 months. it makes a 200 mile round trip to the elevator pretty often is the injector problem something i need 2 fix asap or can it make a few more trips? thank u all for all this you all have given me more solutions than anyone around here
Ttimefr Thanks this. -
I would take it to a good N-14 mechanic that has all the tooling to find the problem and is willing to follow your lead in the repair, not one that wants to tell you nothings wrong with it. I wouldn't put it off too long.
Have you noticed even a slight power loss with this noise occurring? -
at times i think the power is a little less then i think it runs as good as it always has. the other day for a test another rig was in the left lane and we were goin up a little grade and he pulled about half truck ahead and i hit the loud pedel and stayed with him even started pulling on him then i let off to let him pass. i had about 81000 worth corn on. the truck is a repo and someone took a engraver to the engine tag marked out thd cpl number and wrote 500 in the hp u can make out 350 and 435 under neath it also wrote in a new timing code and governed speed of 2100. so i really dont know what hp is it is a black top n14, thanks again for the help.
Ever get it fixed?deereman6030 Thanks this.
First off the valve covers being Red is an option it has absolutely nothing to do with the engine HP or Torque. It is not a coded message, just an option.
You can get the original CPL and numbers from the original equipment truck dealer. Everything else will be in the ECM program.deereman6030 Thanks this. -
No havnt got it figured out yet. just got to call the mechanic to let em know when im dropping it off to do a cut out test. its been slow and been fixing some minor leaks and adjusting brakes just doing a service while its been slow i get it in there next week hopefully.
Meh, drive it until something grenades. You'll find the problem then
Try pressing on the clutch lightly while it's happening and see if it changes. -
A while back I had a rattle I couldn't put my finger on for a long time. I have a 08 Pete 389. Turned out when I finally found it, it was the bushings on the clutch linkage was worn out. I would only hear it under load. Never just cruising along easy or at idle. but as soon as I put a little torque to it the rattle would appear. When the rattle becomes apparent next time just rest your foot on the clutch a little and see if it stops. Just a thought.
Friend of mine wrenches on cars in his own shop, he has a test tool with wires and probes of some sort he can attach to the drive train i think he puts the wire and the sensors out the window and Velcro's it on to the car where he thinks the issue is an then he can narrow the source of the sound when he drive down the road and then finely finds his issue. MAYBE you could talk to the car mechanics in your area an see if they have a tool like that. or even if the diesel shop does
Page 2 of 3
