RD104E issues....
Discussion in 'CB Radio Forum' started by GGALLIN1776, Mar 7, 2023.
  1. GGALLIN1776
    GGALLIN1776 Bobtail Member
    42
    15
    Mar 7, 2023
    Anyone else using this model find it inducing loud "talk back" on radios which have no tb option?
    I thought it was the cheap cobra I was running but on my dx55hp, even with the mic turned all the way down I'm getting talkback & squeal.
    Maybe it's the current skip & the mega stations, but I can't even get someone on the horn for a radio check.
  3. Ridgeline
    22,760
    124,279
    You have an antenna and coax problem, start with you are missing proper RF grounds which can create what is called Common Mode Current.
    Go hear and read about Bonding and Common Mode Current.
    rabbiporkchop and Neverready Thank this.
  4. Night Stalker10
    Night Stalker10 Road Train Member
    1,699
    1,271
    Jun 26, 2017
    These Road devil microphones are a very sensitive mic from what I understand. It's a condenser power mic, plus a noise cancelling mic all in one. You have to keep the gain turned down. It doesn't sound to me like the microphone is your problem, because in another thread you said this..
    "Current road devil power mic is just about the worst. When I bought it, thought the squeal & "talkback" over a non-tb radio was just the cheap radio but it turns out that mic blows out something on the board no matter what you use it on."
    What board are you talking about, the radio? What radio are you using this mic on? You say it works fine on a cheap cobra radio, so that's why I don't think the mic is your problem. Unless I'm reading your posts wrong.
