Re Antenna Tilt
Discussion in 'CB Radio Forum' started by Timin770, Jun 25, 2020.
  1. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    This really has nothing to do with CB but every time I see a tilted antenna it reminds me of the conflict between the Cherokee County GA Sheriffs Office and Clayton County GA SO. The FCC granted both agencies permission to use 158.775 as their dispatch freq. I live in Cherokee Co and quite frequently I'd hear Clayton on that freq. One of the directives from the FCC was for Cherokee to tilt its transmitter antenna a few degrees. You can find the full directive on FCC.gov. Easy to Google
  3. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    Interesting that a small tilt of the antenna would prevent same-frequency conflict.
  4. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    I'm puzzled why the FCC would approve the same freq 40 miles apart
  5. Ridgeline
    22,725
    123,408
    Because of the radiation pattern within the area. The same goes for other services.
  6. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Seems like a risk to approve the same freq so close together. In this case they obviously got it wrong and put lives in peril
  7. Ridgeline
    22,725
    123,408
    Not really, there also is a issue with the application from the counties, some have single frequency use for adjacent counties for operational reasons.
  8. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Is it your position that when neighboring police dispatchers accidentally interfere with each other it's "not really" a problem? If that is your position I'll know what I'm dealing with.
    "some have single frequency use for adjacent counties for operational reasons.."
    Not in this case
  9. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,315
    Jun 10, 2019
    Yes, someone screwed up. You can't have the same freq used in neighboring parishes (or counties for you weird folks). They're going to step on each other. Tilting antennas does nothing but change the radiation pattern and makes reliable communication impossible. It makes for dead spots. Not good advice.
    Timin770 Thanks this.
