Re-use or replace bolts after moving 5th wheel?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ErieMcDreary, Aug 15, 2019.
  1. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    394
    Dec 4, 2016
    Erie PA
    I want to move my non sliding 5th wheel back, I have 12,250# on steer axle, 32,800# on drives.
    I think 2 holes will do it. Do I need to replace the bolts that hold it to the frame, or are they re-usable?
    Short wheelbase 2016 Volvo day cab with 520k on it.
  3. bonder45
    bonder45 Road Train Member
    1,803
    5,455
    Oct 2, 2011
    Williston, ND
    Always buy new, not worth it to re use when they are so cheap to buy.
  4. AModelCat
    166,256
    I wouldn't be afraid to reuse them in a pinch if they didn't look too bad (no excessive rust, damaged threads, stretched etc). Stover/locknuts are one time use though.
  5. Dino soar
    Dino soar Road Train Member
    4,834
    27,111
    Dec 8, 2017
    The bolts themselves may be okay but most likely they have self-locking nuts that should be replaced. For Safety and Security though I would just replace the bolts also.
    I took my fifth wheel plate off to clean the frame and paint it and all that and mine had Huck bolts. I am replacing them with flange bolts and flange nuts.
    Make sure that you use grade 8 bolts and nuts and that you torque them and that after a period of time you torque them again.
    Dave_in_AZ and spsauerland Thank this.
  6. ErieMcDreary
    460
    394
    Dec 4, 2016
    Erie PA
    Thanks. I called the dealer and they recommended replacing them. $100 for 10 bolts and nuts.
  7. Hulld
    Hulld Road Train Member
    2,884
    6,569
    Oct 19, 2015
    Upstate NY
    Check with Fastenal that’s where I got mine.
    Might be a better price.
  8. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    that's cheap insurance....you don't want not even some 3rd rate lawyer bringing that up some day, god forbid something breaks and injures or kills someone.
    Dave_in_AZ and Dino soar Thank this.
  9. REO6205
    REO6205 Road Train Member
    13,168
    60,503
    Feb 15, 2014
    California.
    New bolts and hardware are worth it.
    Dave_in_AZ Thanks this.
  10. ErieMcDreary
    460
    394
    Dec 4, 2016
    Erie PA
    Yes, I agree. I probably could find same size/grade bolts much cheaper, but I don't want to take the chance on failure.
    Dave_in_AZ and buddyd157 Thank this.
  11. AModelCat
    166,256
    The dealer probably buys their bolts from a distributor like Fastenal anyways and then marks them up. As long as the hardware you buy is the same size, length and grade as what you took out you'll be fine.
    12 ga, Diesel Dave, Hulld and 4 others Thank this.
